Group: DynoMotion Message: 5446 From: frank_19_88 Date: 7/20/2012
Subject: spindle speed is not changing at g96 mode mach3 turn
Hi TK,
I am using mach3 turn.
The machine is working very good.
But when I use g96 the spindle speed would not update/change.
The css is changing when the x axis is moving.
When I press +,-,+,-,+,-,+,- at the spindle speed the spindle speed change: 3000rpm at x0 and 100 rpm at x100.
This is a picture of the screen:
http://www.4stepsahead.nl/frank/mach3.jpg
Do you know why the spindle is not updating?
With kind regards,
Frank
Group: DynoMotion Message: 5449 From: Tom Kerekes Date: 7/20/2012
Subject: Re: spindle speed is not changing at g96 mode mach3 turn
Hi Frank,
We don't yet support Lathe CSS.  I would like to add this.
I was experimenting with Mach3.  I can't get Mach3 to work as you describe.  Or rather I don't understand what it is supposed to show.
If I move X to 1.0 and set M3 S250 G96
Then the Mach3 CSS DRO shows +250.
If I then move x to 0.5 then the CSS DRO shows +125.  I was expecting +500.   Does anyone know what I'm doing wrong?  Or what the CSS is supposed to mean?
I don't think Mach3 should perform the CSS anyway because it would be unpredictable and delayed because of Windows and the Buffering.  But I would like to understand it first.
Group: DynoMotion Message: 5456 From: Tom Kerekes Date: 7/22/2012
Hi Frank,
Actually CSS seems to be working for me.
Make sure Config | Ports and Pins | Spindle Setup | Relay Control | Disable Spindle Relays
is NOT checked.
Otherwise Mach3 will not continuously send Plugin Messages while in G96 mode.
Looks like it sends Spindle Messages at about 5X per second whether X is moving or not.
It also took me a while to realize that S is in feet per minute.
I still don't understand exactly what the +CSS value indicates.  Reciprocal of CSS or something.
Group: DynoMotion Message: 5457 From: frank_19_88 Date: 7/22/2012
Hi TK,
I did find a overview about g96:
G48 "Sets the max RPM the spindle will turn (so you don't over speed your work /chuck)
G96 "Sets the mode for constant surface speed (CSS)"
G97 "Sets the mode for constant spindle speed (RPM)"
S "This is the command to set the spindle speed. In CSS mode this is SFM. In RPM mode it is RPM (S after G48 is RPM)"
M3 "Turns the spindle on (clockwise rotation)"
M4 "Turns the spindle on (counterclockwise rotation)"
M5 "Turns the spindle off"
I did uncheck 'Config | Ports and Pins | Spindle Setup | Relay Control | Disable Spindle Relays' but the spindle is still not updating.
My XML file look like this:
- <profile>
- <Preferences>
<PulseSpeed>0</PulseSpeed>
<Profile>Weiler_120</Profile>
<Layout>1024.lset</Layout>
<Configured>1</Configured>
<XRefHome>0</XRefHome>
<YRefHome>0</YRefHome>
<ARefHome>0</ARefHome>
<BRefHome>0</BRefHome>
<CRefHome>0</CRefHome>
<BLState0>1</BLState0>
<BLState1>0</BLState1>
<BLState2>0</BLState2>
<BLState3>0</BLState3>
<BLState4>0</BLState4>
<BLState5>0</BLState5>
<XStart>-183150</XStart>
<YStart>0</YStart>
<ZStart>-209601</ZStart>
<AStart>0</AStart>
<BStart>0</BStart>
<CStart>0</CStart>
<BaudRate>9600</BaudRate>
<ComPort>1</ComPort>
<FeedMode>0</FeedMode>
<AAngular>0</AAngular>
<BAngular>0</BAngular>
<CAngular>0</CAngular>
<BacklashOn>0</BacklashOn>
<PathMode>2</PathMode>
<ThrottleFunc>2</ThrottleFunc>
<JoyOn>0</JoyOn>
<PWMBase>5000</PWMBase>
<JogSpeed>100.</JogSpeed>
<m_SafeZ>0.</m_SafeZ>
<JogInc>1.e-002</JogInc>
<JogSlide>0.1</JogSlide>
<THCMax>1.</THCMax>
<THCMin>0.</THCMin>
<RadiusA>0.</RadiusA>
<RadiusB>0.</RadiusB>
<RadiusC>0.</RadiusC>
<ZRefHome>0</ZRefHome>
<Units>1</Units>
<AxisKeys0>40</AxisKeys0>
<AxisKeys1>38</AxisKeys1>
<AxisKeys2>34834</AxisKeys2>
<AxisKeys3>34834</AxisKeys3>
<AxisKeys4>39</AxisKeys4>
<AxisKeys5>37</AxisKeys5>
<AxisKeys6>999</AxisKeys6>
<AxisKeys7>999</AxisKeys7>
<AxisKeys8>999</AxisKeys8>
<AxisKeys9>999</AxisKeys9>
<AxisKeys10>999</AxisKeys10>
<AxisKeys11>999</AxisKeys11>
<DROHotKey>999</DROHotKey>
<MDIHotKey>999</MDIHotKey>
<GCodeHotKey>999</GCodeHotKey>
<XRev>0</XRev>
<YRev>0</YRev>
<ZRev>1</ZRev>
<ARev>0</ARev>
<BRev>0</BRev>
<CRev>0</CRev>
<SpinCCW>8</SpinCCW>
<SpinCW>7</SpinCW>
<Flood>9</Flood>
<Mist>10</Mist>
<SpinDelay>2.</SpinDelay>
<NoSpindle>0</NoSpindle>
<NoFlood>1</NoFlood>
<RefSpeed0>1</RefSpeed0>
<RefSpeed1>1</RefSpeed1>
<RefSpeed2>1</RefSpeed2>
<RefSpeed3>1</RefSpeed3>
<RefSpeed4>1</RefSpeed4>
<RefSpeed5>1</RefSpeed5>
<FullSpeed>0</FullSpeed>
<XNeg>0</XNeg>
<YNeg>0</YNeg>
<ZNeg>0</ZNeg>
<ANeg>0</ANeg>
<BNeg>0</BNeg>
<CNeg>0</CNeg>
<AutoZero>1</AutoZero>
<Enc0Cal>1.</Enc0Cal>
<Enc1Cal>1.</Enc1Cal>
<Enc2Cal>1.</Enc2Cal>
<BackX>0.</BackX>
<BackY>0.</BackY>
<BackZ>0.</BackZ>
<BackA>0.</BackA>
<BackB>0.</BackB>
<BackC>0.</BackC>
<BackSpeed>20.</BackSpeed>
<SlavePrim>0</SlavePrim>
<Slave>-1</Slave>
<SpinActual>1</SpinActual>
<AutoTurnOff>0</AutoTurnOff>
<AutoEStop>0</AutoEStop>
<G92Off>0</G92Off>
<ToolOffsetOff>1</ToolOffsetOff>
<RadiusCompOff>1</RadiusCompOff>
<OriginsOff>1</OriginsOff>
<SPEED1>2900</SPEED1>
<SPEED2>3000</SPEED2>
<SPEED3>8000</SPEED3>
<SPEED4>16000</SPEED4>
<PULLEY>0</PULLEY>
<Editor>C:\WINDOWS\notepad.exe</Editor>
<Debounce>500</Debounce>
<PWMin>0</PWMin>
<DROPERSIST>1</DROPERSIST>
<IJMode>1</IJMode>
<BB>0.0</BB>
<BR>0.0</BR>
<BG>0.0</BG>
<FB>1.0</FB>
<FR>0.0</FR>
<FG>0.0</FG>
<RB>0.0</RB>
<RR>1.0</RR>
<RG>0.0</RG>
<AB>0.7</AB>
<AR>0.7</AR>
<AG>0.2</AG>
<EG>1.0</EG>
<ER>1.0</ER>
<EB>0.0</EB>
<Compass>1</Compass>
<XMax>9999.</XMax>
<YMax>9999.</YMax>
<ZMax>9999.</ZMax>
<XMin>0.</XMin>
<YMin>0.</YMin>
<ZMin>0.</ZMin>
<SoftRampX>1.</SoftRampX>
<SoftRampY>1.</SoftRampY>
<SoftRampZ>1.</SoftRampZ>
<Vel0>66.67</Vel0>
<Acc0>300.</Acc0>
<Steps0>1000.</Steps0>
<Vel1>33.33</Vel1>
<Acc1>150.</Acc1>
<Steps1>2000.</Steps1>
<Vel2>33.33</Vel2>
<Acc2>150.</Acc2>
<Steps2>2000.</Steps2>
<PulseWidth>0</PulseWidth>
<DirPulse>0</DirPulse>
<GPath>C:\Users\4StepsAhead BV\Desktop\Das Special Products\Membraandop\Membraandop axiaal nadraaien.txt</GPath>
<AAxisOn>0</AAxisOn>
<PWM>0</PWM>
<BAxisOn>0</BAxisOn>
<CAxisOn>0</CAxisOn>
<XAxisOn>1</XAxisOn>
<YAxisOn>0</YAxisOn>
<ZAxisOn>1</ZAxisOn>
<SpindleControl>0</SpindleControl>
<Port2On>0</Port2On>
<Port1On>1</Port1On>
<Port1Add>888</Port1Add>
<Port2Add>632</Port2Add>
<Activate1In>0</Activate1In>
<Activate2In>0</Activate2In>
<Activate3In>0</Activate3In>
<Activate4In>0</Activate4In>
<DigitizeIn>0</DigitizeIn>
<Encoder1>0</Encoder1>
<Encoder2>-209601</Encoder2>
<Encoder3>0</Encoder3>
<HomeA>0</HomeA>
<HomeB>0</HomeB>
<HomeC>0</HomeC>
<HomeX>0</HomeX>
<HomeY>0</HomeY>
<HomeZ>0</HomeZ>
<IndexPulse>0</IndexPulse>
<THCOn>0</THCOn>
<LimitAMinus>0</LimitAMinus>
<LimitBMinus>0</LimitBMinus>
<LimitCMinus>0</LimitCMinus>
<LimitXMinus>0</LimitXMinus>
<LimitYMinus>0</LimitYMinus>
<LimitZMinus>0</LimitZMinus>
<LimitAPlus>0</LimitAPlus>
<LimitBPlus>0</LimitBPlus>
<LimitCPlus>0</LimitCPlus>
<LimitXPlus>0</LimitXPlus>
<LimitYPlus>0</LimitYPlus>
<LimitZPlus>0</LimitZPlus>
<LimitOverRide>0</LimitOverRide>
<XDirPort>1</XDirPort>
<XDirPin>3</XDirPin>
<XStepPort>1</XStepPort>
<XStepPin>2</XStepPin>
<XDirNeg>1</XDirNeg>
<XStepNeg>1</XStepNeg>
<YDirPort>1</YDirPort>
<YDirPin>5</YDirPin>
<YStepPort>1</YStepPort>
<YStepPin>4</YStepPin>
<YDirNeg>0</YDirNeg>
<YStepNeg>0</YStepNeg>
<ZDirPort>1</ZDirPort>
<ZDirPin>7</ZDirPin>
<ZStepPort>1</ZStepPort>
<ZStepPin>6</ZStepPin>
<ZDirNeg>1</ZDirNeg>
<ZStepNeg>1</ZStepNeg>
<ADirPort>1</ADirPort>
<ADirPin>8</ADirPin>
<AStepPort>1</AStepPort>
<AStepPin>9</AStepPin>
<ADirNeg>0</ADirNeg>
<AStepNeg>0</AStepNeg>
<BDirPort>0</BDirPort>
<BDirPin>0</BDirPin>
<BStepPort>0</BStepPort>
<BStepPin>0</BStepPin>
<BDirNeg>0</BDirNeg>
<BStepNeg>0</BStepNeg>
<CDirPort>0</CDirPort>
<CDirPin>0</CDirPin>
<CStepPort>0</CStepPort>
<CStepPin>0</CStepPin>
<CDirNeg>0</CDirNeg>
<CStepNeg>0</CStepNeg>
<SPDirPort>0</SPDirPort>
<SPDirPin>0</SPDirPin>
<SPStepPort>0</SPStepPort>
<SPStepPin>0</SPStepPin>
<SPDirNeg>0</SPDirNeg>
<SPStepNeg>0</SPStepNeg>
<Enable1Pin>17</Enable1Pin>
<Enable1Port>1</Enable1Port>
<Enable2Pin>0</Enable2Pin>
<Enable2Port>0</Enable2Port>
<Enable3Pin>0</Enable3Pin>
<Enable3Port>0</Enable3Port>
<Enable4Pin>0</Enable4Pin>
<Enable4Port>0</Enable4Port>
<Enable5Pin>0</Enable5Pin>
<Enable5Port>0</Enable5Port>
<Enable6Pin>0</Enable6Pin>
<Enable6Port>0</Enable6Port>
<Enable1Neg>1</Enable1Neg>
<Enable2Neg>0</Enable2Neg>
<Enable3Neg>0</Enable3Neg>
<Enable4Neg>0</Enable4Neg>
<Enable5Neg>0</Enable5Neg>
<Enable6Neg>0</Enable6Neg>
<Extern1Neg>0</Extern1Neg>
<Extern2Neg>0</Extern2Neg>
<Extern3Neg>0</Extern3Neg>
<TrigDigitizeNeg>0</TrigDigitizeNeg>
<TrigDigPin>0</TrigDigPin>
<TrigDigPort>0</TrigDigPort>
<Extern1Pin>1</Extern1Pin>
<Extern1Port>1</Extern1Port>
<Extern2Pin>14</Extern2Pin>
<Extern2Port>1</Extern2Port>
<Extern3Pin>16</Extern3Pin>
<Extern3Port>1</Extern3Port>
<ChargePin>16</ChargePin>
<ChargePort>1</ChargePort>
<OutActive1>0</OutActive1>
<OutActive2>0</OutActive2>
<OutActive3>0</OutActive3>
<Enable1>1</Enable1>
<Enable2>0</Enable2>
<Enable3>0</Enable3>
<Enable4>0</Enable4>
<Enable5>0</Enable5>
<Enable6>0</Enable6>
<Charge>0</Charge>
<TrigDigitize>0</TrigDigitize>
<Active1Pin>10</Active1Pin>
<Active1Port>1</Active1Port>
<Active2Pin>10</Active2Pin>
<Active2Port>1</Active2Port>
<Active3Pin>10</Active3Pin>
<Active3Port>1</Active3Port>
<Active4Pin>10</Active4Pin>
<Active4Port>1</Active4Port>
<RaisePin>11</RaisePin>
<RaisePort>1</RaisePort>
<LowerPin>12</LowerPin>
<LowerPort>1</LowerPort>
<TorchOnPin>10</TorchOnPin>
<TorchOnPort>1</TorchOnPort>
<TorchOnNeg>0</TorchOnNeg>
<RaiseNeg>0</RaiseNeg>
<LowerNeg>0</LowerNeg>
<HomeAPin>10</HomeAPin>
<HomeAPort>1</HomeAPort>
<HomeBPin>10</HomeBPin>
<HomeBPort>1</HomeBPort>
<HomeCPin>10</HomeCPin>
<HomeCPort>1</HomeCPort>
<HomeXPin>10</HomeXPin>
<HomeXPort>1</HomeXPort>
<HomeYPin>10</HomeYPin>
<HomeYPort>1</HomeYPort>
<HomeZPin>10</HomeZPin>
<HomeZPort>1</HomeZPort>
<IndexPin>10</IndexPin>
<IndexPort>1</IndexPort>
<LimitsOvPin>10</LimitsOvPin>
<LimitsOvPort>1</LimitsOvPort>
<LimitAMinusPin>0</LimitAMinusPin>
<LimitAMinusPort>1</LimitAMinusPort>
<LimitBMinusPin>0</LimitBMinusPin>
<LimitBMinusPort>1</LimitBMinusPort>
<LimitCMinusPin>0</LimitCMinusPin>
<LimitCMinusPort>1</LimitCMinusPort>
<LimitXMinusPin>11</LimitXMinusPin>
<LimitXMinusPort>1</LimitXMinusPort>
<LimitYMinusPin>12</LimitYMinusPin>
<LimitYMinusPort>1</LimitYMinusPort>
<LimitZMinusPin>0</LimitZMinusPin>
<LimitZMinusPort>1</LimitZMinusPort>
<LimitAPlusPin>0</LimitAPlusPin>
<LimitAPlusPort>1</LimitAPlusPort>
<LimitBPlusPin>0</LimitBPlusPin>
<LimitBPlusPort>1</LimitBPlusPort>
<LimitCPlusPin>0</LimitCPlusPin>
<LimitCPlusPort>1</LimitCPlusPort>
<LimitXPlusPin>0</LimitXPlusPin>
<LimitXPlusPort>1</LimitXPlusPort>
<LimitYPlusPin>0</LimitYPlusPin>
<LimitYPlusPort>1</LimitYPlusPort>
<LimitZPlusPin>13</LimitZPlusPin>
<LimitZPlusPort>1</LimitZPlusPort>
<EmergencyPin>10</EmergencyPin>
<EmergencyPort>1</EmergencyPort>
<DigitizePin>10</DigitizePin>
<DigitizePort>1</DigitizePort>
<EmergencyNeg>1</EmergencyNeg>
<Activate1Neg>0</Activate1Neg>
<Activate2Neg>0</Activate2Neg>
<Activate3Neg>0</Activate3Neg>
<Activate4Neg>0</Activate4Neg>
<DigitizeNeg>0</DigitizeNeg>
<HomeANeg>0</HomeANeg>
<HomeBNeg>0</HomeBNeg>
<HomeCNeg>0</HomeCNeg>
<HomeXNeg>0</HomeXNeg>
<HomeYNeg>0</HomeYNeg>
<HomeZNeg>0</HomeZNeg>
<IndexNeg>0</IndexNeg>
<LimitOverRideNeg>0</LimitOverRideNeg>
<LimitAMinusNeg>0</LimitAMinusNeg>
<LimitBMinusNeg>0</LimitBMinusNeg>
<LimitCMinusNeg>0</LimitCMinusNeg>
<LimitXMinusNeg>1</LimitXMinusNeg>
<LimitYMinusNeg>1</LimitYMinusNeg>
<LimitZMinusNeg>0</LimitZMinusNeg>
<LimitAPlusNeg>0</LimitAPlusNeg>
<LimitBPlusNeg>0</LimitBPlusNeg>
<LimitCPlusNeg>0</LimitCPlusNeg>
<LimitXPlusNeg>0</LimitXPlusNeg>
<LimitYPlusNeg>0</LimitYPlusNeg>
<LimitZPlusNeg>1</LimitZPlusNeg>
<Motor0Active>1</Motor0Active>
<Motor0DirNeg>1</Motor0DirNeg>
<Motor0DirPort>1</Motor0DirPort>
<Motor0DirPin>3</Motor0DirPin>
<Motor0StepNeg>1</Motor0StepNeg>
<Motor0StepPort>1</Motor0StepPort>
<Motor0StepPin>2</Motor0StepPin>
<Motor1Active>0</Motor1Active>
<Motor1DirNeg>0</Motor1DirNeg>
<Motor1DirPort>0</Motor1DirPort>
<Motor1DirPin>0</Motor1DirPin>
<Motor1StepNeg>0</Motor1StepNeg>
<Motor1StepPort>0</Motor1StepPort>
<Motor1StepPin>0</Motor1StepPin>
<Motor2Active>1</Motor2Active>
<Motor2DirNeg>1</Motor2DirNeg>
<Motor2DirPort>1</Motor2DirPort>
<Motor2DirPin>7</Motor2DirPin>
<Motor2StepNeg>1</Motor2StepNeg>
<Motor2StepPort>1</Motor2StepPort>
<Motor2StepPin>6</Motor2StepPin>
<Motor3Active>0</Motor3Active>
<Motor3DirNeg>0</Motor3DirNeg>
<Motor3DirPort>0</Motor3DirPort>
<Motor3DirPin>0</Motor3DirPin>
<Motor3StepNeg>0</Motor3StepNeg>
<Motor3StepPort>0</Motor3StepPort>
<Motor3StepPin>0</Motor3StepPin>
<Motor4Active>0</Motor4Active>
<Motor4DirNeg>0</Motor4DirNeg>
<Motor4DirPort>0</Motor4DirPort>
<Motor4DirPin>0</Motor4DirPin>
<Motor4StepNeg>0</Motor4StepNeg>
<Motor4StepPort>0</Motor4StepPort>
<Motor4StepPin>0</Motor4StepPin>
<Motor5Active>0</Motor5Active>
<Motor5DirNeg>0</Motor5DirNeg>
<Motor5DirPort>0</Motor5DirPort>
<Motor5DirPin>0</Motor5DirPin>
<Motor5StepNeg>0</Motor5StepNeg>
<Motor5StepPort>0</Motor5StepPort>
<Motor5StepPin>0</Motor5StepPin>
<Motor6Active>1</Motor6Active>
<Motor6DirNeg>0</Motor6DirNeg>
<Motor6DirPort>0</Motor6DirPort>
<Motor6DirPin>0</Motor6DirPin>
<Motor6StepNeg>0</Motor6StepNeg>
<Motor6StepPort>0</Motor6StepPort>
<Motor6StepPin>0</Motor6StepPin>
<GeckoMode>0</GeckoMode>
<USBINPUTS>16</USBINPUTS>
<USBOUTPUTS>16</USBOUTPUTS>
<MaxCL>0</MaxCL>
<MaxNC10>0</MaxNC10>
<Input0Active>1</Input0Active>
<Input0Port>1</Input0Port>
<Input0Pin>49</Input0Pin>
<Input0Neg>0</Input0Neg>
<Input0Emulated>0</Input0Emulated>
<Input0EmuKey>0</Input0EmuKey>
<Input1Active>1</Input1Active>
<Input1Port>1</Input1Port>
<Input1Pin>48</Input1Pin>
<Input1Neg>0</Input1Neg>
<Input1Emulated>0</Input1Emulated>
<Input1EmuKey>0</Input1EmuKey>
<Input2Active>0</Input2Active>
<Input2Port>0</Input2Port>
<Input2Pin>0</Input2Pin>
<Input2Neg>0</Input2Neg>
<Input2Emulated>0</Input2Emulated>
<Input2EmuKey>0</Input2EmuKey>
<Input3Active>1</Input3Active>
<Input3Port>2</Input3Port>
<Input3Pin>8</Input3Pin>
<Input3Neg>0</Input3Neg>
<Input3Emulated>0</Input3Emulated>
<Input3EmuKey>0</Input3EmuKey>
<Input4Active>1</Input4Active>
<Input4Port>2</Input4Port>
<Input4Pin>9</Input4Pin>
<Input4Neg>0</Input4Neg>
<Input4Emulated>0</Input4Emulated>
<Input4EmuKey>0</Input4EmuKey>
<Input5Active>0</Input5Active>
<Input5Port>0</Input5Port>
<Input5Pin>0</Input5Pin>
<Input5Neg>0</Input5Neg>
<Input5Emulated>0</Input5Emulated>
<Input5EmuKey>0</Input5EmuKey>
<Input6Active>1</Input6Active>
<Input6Port>1</Input6Port>
<Input6Pin>51</Input6Pin>
<Input6Neg>0</Input6Neg>
<Input6Emulated>0</Input6Emulated>
<Input6EmuKey>0</Input6EmuKey>
<Input7Active>1</Input7Active>
<Input7Port>1</Input7Port>
<Input7Pin>50</Input7Pin>
<Input7Neg>0</Input7Neg>
<Input7Emulated>0</Input7Emulated>
<Input7EmuKey>0</Input7EmuKey>
<Input8Active>0</Input8Active>
<Input8Port>0</Input8Port>
<Input8Pin>0</Input8Pin>
<Input8Neg>0</Input8Neg>
<Input8Emulated>0</Input8Emulated>
<Input8EmuKey>0</Input8EmuKey>
<Input9Active>1</Input9Active>
<Input9Port>1</Input9Port>
<Input9Pin>53</Input9Pin>
<Input9Neg>0</Input9Neg>
<Input9Emulated>0</Input9Emulated>
<Input9EmuKey>0</Input9EmuKey>
<Input10Active>1</Input10Active>
<Input10Port>1</Input10Port>
<Input10Pin>52</Input10Pin>
<Input10Neg>0</Input10Neg>
<Input10Emulated>0</Input10Emulated>
<Input10EmuKey>0</Input10EmuKey>
<Input11Active>0</Input11Active>
<Input11Port>0</Input11Port>
<Input11Pin>0</Input11Pin>
<Input11Neg>0</Input11Neg>
<Input11Emulated>0</Input11Emulated>
<Input11EmuKey>0</Input11EmuKey>
<Input12Active>1</Input12Active>
<Input12Port>2</Input12Port>
<Input12Pin>10</Input12Pin>
<Input12Neg>1</Input12Neg>
<Input12Emulated>0</Input12Emulated>
<Input12EmuKey>0</Input12EmuKey>
<Input13Active>1</Input13Active>
<Input13Port>1</Input13Port>
<Input13Pin>31</Input13Pin>
<Input13Neg>1</Input13Neg>
<Input13Emulated>0</Input13Emulated>
<Input13EmuKey>0</Input13EmuKey>
<Input14Active>0</Input14Active>
<Input14Port>0</Input14Port>
<Input14Pin>0</Input14Pin>
<Input14Neg>0</Input14Neg>
<Input14Emulated>0</Input14Emulated>
<Input14EmuKey>0</Input14EmuKey>
<Input15Active>1</Input15Active>
<Input15Port>2</Input15Port>
<Input15Pin>12</Input15Pin>
<Input15Neg>1</Input15Neg>
<Input15Emulated>0</Input15Emulated>
<Input15EmuKey>0</Input15EmuKey>
<Input16Active>1</Input16Active>
<Input16Port>2</Input16Port>
<Input16Pin>13</Input16Pin>
<Input16Neg>1</Input16Neg>
<Input16Emulated>0</Input16Emulated>
<Input16EmuKey>0</Input16EmuKey>
<Input17Active>0</Input17Active>
<Input17Port>0</Input17Port>
<Input17Pin>0</Input17Pin>
<Input17Neg>0</Input17Neg>
<Input17Emulated>0</Input17Emulated>
<Input17EmuKey>0</Input17EmuKey>
<Input18Active>1</Input18Active>
<Input18Port>2</Input18Port>
<Input18Pin>14</Input18Pin>
<Input18Neg>1</Input18Neg>
<Input18Emulated>0</Input18Emulated>
<Input18EmuKey>0</Input18EmuKey>
<Input19Active>1</Input19Active>
<Input19Port>2</Input19Port>
<Input19Pin>15</Input19Pin>
<Input19Neg>1</Input19Neg>
<Input19Emulated>0</Input19Emulated>
<Input19EmuKey>0</Input19EmuKey>
<Input20Active>1</Input20Active>
<Input20Port>1</Input20Port>
<Input20Pin>29</Input20Pin>
<Input20Neg>1</Input20Neg>
<Input20Emulated>0</Input20Emulated>
<Input20EmuKey>0</Input20EmuKey>
<Input21Active>1</Input21Active>
<Input21Port>1</Input21Port>
<Input21Pin>30</Input21Pin>
<Input21Neg>1</Input21Neg>
<Input21Emulated>0</Input21Emulated>
<Input21EmuKey>0</Input21EmuKey>
<Input22Active>0</Input22Active>
<Input22Port>0</Input22Port>
<Input22Pin>0</Input22Pin>
<Input22Neg>0</Input22Neg>
<Input22Emulated>0</Input22Emulated>
<Input22EmuKey>0</Input22EmuKey>
<Input23Active>0</Input23Active>
<Input23Port>0</Input23Port>
<Input23Pin>0</Input23Pin>
<Input23Neg>0</Input23Neg>
<Input23Emulated>0</Input23Emulated>
<Input23EmuKey>0</Input23EmuKey>
<Input24Active>0</Input24Active>
<Input24Port>0</Input24Port>
<Input24Pin>0</Input24Pin>
<Input24Neg>0</Input24Neg>
<Input24Emulated>0</Input24Emulated>
<Input24EmuKey>0</Input24EmuKey>
<Input25Active>1</Input25Active>
<Input25Port>1</Input25Port>
<Input25Pin>31</Input25Pin>
<Input25Neg>1</Input25Neg>
<Input25Emulated>0</Input25Emulated>
<Input25EmuKey>0</Input25EmuKey>
<Input26Active>0</Input26Active>
<Input26Port>0</Input26Port>
<Input26Pin>0</Input26Pin>
<Input26Neg>0</Input26Neg>
<Input26Emulated>0</Input26Emulated>
<Input26EmuKey>0</Input26EmuKey>
<Input27Active>0</Input27Active>
<Input27Port>0</Input27Port>
<Input27Pin>0</Input27Pin>
<Input27Neg>0</Input27Neg>
<Input27Emulated>0</Input27Emulated>
<Input27EmuKey>0</Input27EmuKey>
<Input28Active>0</Input28Active>
<Input28Port>0</Input28Port>
<Input28Pin>0</Input28Pin>
<Input28Neg>0</Input28Neg>
<Input28Emulated>0</Input28Emulated>
<Input28EmuKey>0</Input28EmuKey>
<Input29Active>0</Input29Active>
<Input29Port>0</Input29Port>
<Input29Pin>0</Input29Pin>
<Input29Neg>0</Input29Neg>
<Input29Emulated>0</Input29Emulated>
<Input29EmuKey>0</Input29EmuKey>
<Input30Active>0</Input30Active>
<Input30Port>0</Input30Port>
<Input30Pin>0</Input30Pin>
<Input30Neg>0</Input30Neg>
<Input30Emulated>0</Input30Emulated>
<Input30EmuKey>0</Input30EmuKey>
<Input31Active>0</Input31Active>
<Input31Port>0</Input31Port>
<Input31Pin>0</Input31Pin>
<Input31Neg>0</Input31Neg>
<Input31Emulated>0</Input31Emulated>
<Input31EmuKey>0</Input31EmuKey>
<Input32Active>0</Input32Active>
<Input32Port>0</Input32Port>
<Input32Pin>0</Input32Pin>
<Input32Neg>0</Input32Neg>
<Input32Emulated>0</Input32Emulated>
<Input32EmuKey>0</Input32EmuKey>
<Input33Active>0</Input33Active>
<Input33Port>0</Input33Port>
<Input33Pin>0</Input33Pin>
<Input33Neg>0</Input33Neg>
<Input33Emulated>0</Input33Emulated>
<Input33EmuKey>0</Input33EmuKey>
<Input34Active>0</Input34Active>
<Input34Port>0</Input34Port>
<Input34Pin>0</Input34Pin>
<Input34Neg>0</Input34Neg>
<Input34Emulated>0</Input34Emulated>
<Input34EmuKey>0</Input34EmuKey>
<Input35Active>0</Input35Active>
<Input35Port>0</Input35Port>
<Input35Pin>0</Input35Pin>
<Input35Neg>0</Input35Neg>
<Input35Emulated>0</Input35Emulated>
<Input35EmuKey>0</Input35EmuKey>
<Output0Active>0</Output0Active>
<Output0Port>0</Output0Port>
<Output0Pin>0</Output0Pin>
<Output0Neg>0</Output0Neg>
<Output1Active>1</Output1Active>
<Output1Port>1</Output1Port>
<Output1Pin>61</Output1Pin>
<Output1Neg>0</Output1Neg>
<Output2Active>0</Output2Active>
<Output2Port>0</Output2Port>
<Output2Pin>0</Output2Pin>
<Output2Neg>0</Output2Neg>
<Output3Active>0</Output3Active>
<Output3Port>0</Output3Port>
<Output3Pin>0</Output3Pin>
<Output3Neg>0</Output3Neg>
<Output4Active>0</Output4Active>
<Output4Port>0</Output4Port>
<Output4Pin>0</Output4Pin>
<Output4Neg>0</Output4Neg>
<Output5Active>0</Output5Active>
<Output5Port>0</Output5Port>
<Output5Pin>0</Output5Pin>
<Output5Neg>0</Output5Neg>
<Output6Active>0</Output6Active>
<Output6Port>0</Output6Port>
<Output6Pin>0</Output6Pin>
<Output6Neg>0</Output6Neg>
<Output7Active>0</Output7Active>
<Output7Port>0</Output7Port>
<Output7Pin>0</Output7Pin>
<Output7Neg>0</Output7Neg>
<Output8Active>0</Output8Active>
<Output8Port>0</Output8Port>
<Output8Pin>0</Output8Pin>
<Output8Neg>0</Output8Neg>
<Output9Active>1</Output9Active>
<Output9Port>1</Output9Port>
<Output9Pin>33</Output9Pin>
<Output9Neg>0</Output9Neg>
<Output10Active>0</Output10Active>
<Output10Port>0</Output10Port>
<Output10Pin>0</Output10Pin>
<Output10Neg>0</Output10Neg>
<Output11Active>0</Output11Active>
<Output11Port>0</Output11Port>
<Output11Pin>0</Output11Pin>
<Output11Neg>0</Output11Neg>
<Output12Active>0</Output12Active>
<Output12Port>0</Output12Port>
<Output12Pin>0</Output12Pin>
<Output12Neg>0</Output12Neg>
<Output13Active>0</Output13Active>
<Output13Port>0</Output13Port>
<Output13Pin>0</Output13Pin>
<Output13Neg>0</Output13Neg>
<Output14Active>0</Output14Active>
<Output14Port>0</Output14Port>
<Output14Pin>0</Output14Pin>
<Output14Neg>0</Output14Neg>
<Output15Active>0</Output15Active>
<Output15Port>0</Output15Port>
<Output15Pin>0</Output15Pin>
<Output15Neg>0</Output15Neg>
<Encoder0Active>0</Encoder0Active>
<Encoder0APort>0</Encoder0APort>
<Encoder0APin>0</Encoder0APin>
<Encoder0BPort>0</Encoder0BPort>
<Encoder0BPin>0</Encoder0BPin>
<Encoder0Cal>1.000000</Encoder0Cal>
<Encoder1Active>0</Encoder1Active>
<Encoder1APort>0</Encoder1APort>
<Encoder1APin>0</Encoder1APin>
<Encoder1BPort>0</Encoder1BPort>
<Encoder1BPin>0</Encoder1BPin>
<Encoder1Cal>1.000000</Encoder1Cal>
<Encoder2Active>0</Encoder2Active>
<Encoder2APort>0</Encoder2APort>
<Encoder2APin>0</Encoder2APin>
<Encoder2BPort>0</Encoder2BPort>
<Encoder2BPin>0</Encoder2BPin>
<Encoder2Cal>1.000000</Encoder2Cal>
<Encoder3Active>0</Encoder3Active>
<Encoder3APort>0</Encoder3APort>
<Encoder3APin>0</Encoder3APin>
<Encoder3BPort>0</Encoder3BPort>
<Encoder3BPin>0</Encoder3BPin>
<Encoder3Cal>1.000000</Encoder3Cal>
<Encoder4Active>1</Encoder4Active>
<Encoder4APort>1</Encoder4APort>
<Encoder4APin>13</Encoder4APin>
<Encoder4BPort>1</Encoder4BPort>
<Encoder4BPin>15</Encoder4BPin>
<Encoder4Cal>5.000000</Encoder4Cal>
<Encoder5Active>0</Encoder5Active>
<Encoder5APort>0</Encoder5APort>
<Encoder5APin>0</Encoder5APin>
<Encoder5BPort>0</Encoder5BPort>
<Encoder5BPin>0</Encoder5BPin>
<Encoder5Cal>1.000000</Encoder5Cal>
<Encoder6Active>0</Encoder6Active>
<Encoder6APort>0</Encoder6APort>
<Encoder6APin>0</Encoder6APin>
<Encoder6BPort>0</Encoder6BPort>
<Encoder6BPin>0</Encoder6BPin>
<Encoder6Cal>1.000000</Encoder6Cal>
<Encoder7Active>0</Encoder7Active>
<Encoder7APort>0</Encoder7APort>
<Encoder7APin>0</Encoder7APin>
<Encoder7BPort>0</Encoder7BPort>
<Encoder7BPin>0</Encoder7BPin>
<Encoder7Cal />
<M0SoftRamp>1.</M0SoftRamp>
<M1SoftRamp>1.</M1SoftRamp>
<M2SoftRamp>1.</M2SoftRamp>
<M3SoftRamp>1.</M3SoftRamp>
<M4SoftRamp>1.</M4SoftRamp>
<M5SoftRamp>1.</M5SoftRamp>
<M0Max>100.</M0Max>
<M1Max>100.</M1Max>
<M2Max>100.</M2Max>
<M3Max>100.</M3Max>
<M4Max>100.</M4Max>
<M5Max>100.</M5Max>
<M0Min>-100.</M0Min>
<M1Min>-100.</M1Min>
<M2Min>-100.</M2Min>
<M3Min>-100.</M3Min>
<M4Min>-100.</M4Min>
<M5Min>-100.</M5Min>
<M0Neg>0</M0Neg>
<M1Neg>0</M1Neg>
<M2Neg>0</M2Neg>
<M3Neg>0</M3Neg>
<M4Neg>0</M4Neg>
<M5Neg>0</M5Neg>
<M0AutoZero>1</M0AutoZero>
<M1AutoZero>1</M1AutoZero>
<M2AutoZero>1</M2AutoZero>
<M3AutoZero>1</M3AutoZero>
<M4AutoZero>1</M4AutoZero>
<M5AutoZero>1</M5AutoZero>
<M0Rev>1</M0Rev>
<M1Rev>0</M1Rev>
<M2Rev>0</M2Rev>
<M3Rev>0</M3Rev>
<M4Rev>0</M4Rev>
<M5Rev>0</M5Rev>
<M6Rev>0</M6Rev>
<OffPersist>1</OffPersist>
<Diameter>0</Diameter>
<OffDialogs>1</OffDialogs>
<G54Back>0</G54Back>
<GougeCheck>0</GougeCheck>
<AxisToMotor0>0</AxisToMotor0>
<AxisToMotor1>1</AxisToMotor1>
<AxisToMotor2>2</AxisToMotor2>
<AxisToMotor3>3</AxisToMotor3>
<AxisToMotor4>4</AxisToMotor4>
<AxisToMotor5>5</AxisToMotor5>
<AxisToMotor6>6</AxisToMotor6>
<JogActive>1</JogActive>
<SlowMode>0</SlowMode>
<JogPersist>1</JogPersist>
<ToolRotations>0</ToolRotations>
<SoftLimit>0</SoftLimit>
<JogMode>0</JogMode>
<SpinInc>10</SpinInc>
<TangentalControl>0</TangentalControl>
<NoPlunge>0</NoPlunge>
<PlungeLimit>60</PlungeLimit>
<AutoTool>0</AutoTool>
<AutoSpindle>0</AutoSpindle>
<LaserMode>0</LaserMode>
<OriginSphere>0</OriginSphere>
<m_3dCompass>1</m_3dCompass>
<Boundries>0</Boundries>
<ToolPosition>0</ToolPosition>
<AParallel>-1</AParallel>
<ZINHPersist>0</ZINHPersist>
<OVPersist>0</OVPersist>
<G73PullBack>0.1</G73PullBack>
<CVFeedOn>0</CVFeedOn>
<CVFeedRate>1.</CVFeedRate>
<AtoX>-6.277e+066</AtoX>
<AtoY>-6.277e+066</AtoY>
<AtoZ>-6.277e+066</AtoZ>
<OEMDRO0>0.</OEMDRO0>
<OEMLED0>0</OEMLED0>
<OEMDRO1>0.</OEMDRO1>
<OEMLED1>0</OEMLED1>
<OEMDRO2>0.</OEMDRO2>
<OEMLED2>0</OEMLED2>
<OEMDRO3>0.</OEMDRO3>
<OEMLED3>1</OEMLED3>
<OEMDRO4>0.</OEMDRO4>
<OEMLED4>0</OEMLED4>
<OEMDRO5>10.</OEMDRO5>
<OEMLED5>1</OEMLED5>
<OEMDRO6>0.1</OEMDRO6>
<OEMLED6>0</OEMLED6>
<OEMDRO7>10.</OEMDRO7>
<OEMLED7>0</OEMLED7>
<OEMDRO8>0.</OEMDRO8>
<OEMLED8>0</OEMLED8>
<OEMDRO9>2.5e-002</OEMDRO9>
<OEMLED9>0</OEMLED9>
<OEMDRO10>0.13</OEMDRO10>
<OEMLED10>0</OEMLED10>
<OEMDRO11>5.e-002</OEMDRO11>
<OEMLED11>0</OEMLED11>
<OEMDRO12>0.1</OEMDRO12>
<OEMLED12>0</OEMLED12>
<OEMDRO13>29.</OEMDRO13>
<OEMLED13>0</OEMLED13>
<OEMDRO14>1.</OEMDRO14>
<OEMLED14>0</OEMLED14>
<OEMDRO15>1.e-004</OEMDRO15>
<OEMLED15>0</OEMLED15>
<OEMDRO16>9.5</OEMDRO16>
<OEMLED16>0</OEMLED16>
<OEMDRO17>45.</OEMDRO17>
<OEMLED17>0</OEMLED17>
<OEMDRO18>0.</OEMDRO18>
<OEMLED18>0</OEMLED18>
<OEMDRO19>2.</OEMDRO19>
<OEMLED19>0</OEMLED19>
<OEMDRO20>0.3</OEMDRO20>
<OEMLED20>1</OEMLED20>
<OEMDRO21>3.e-003</OEMDRO21>
<OEMLED21>0</OEMLED21>
<OEMDRO22>25.</OEMDRO22>
<OEMLED22>0</OEMLED22>
<OEMDRO23>0.</OEMDRO23>
<OEMLED23>0</OEMLED23>
<OEMDRO24>0.</OEMDRO24>
<OEMLED24>1</OEMLED24>
<OEMDRO25>0.</OEMDRO25>
<OEMLED25>0</OEMLED25>
<OEMDRO26>0.</OEMDRO26>
<OEMLED26>0</OEMLED26>
<OEMDRO27>0.</OEMDRO27>
<OEMLED27>0</OEMLED27>
<OEMDRO28>0.</OEMDRO28>
<OEMLED28>0</OEMLED28>
<OEMDRO29>30.09375</OEMDRO29>
<OEMLED29>0</OEMLED29>
<OEMDRO30>10.</OEMDRO30>
<OEMLED30>0</OEMLED30>
<OEMDRO31>2000.</OEMDRO31>
<OEMLED31>0</OEMLED31>
<OEMDRO32>200.</OEMDRO32>
<OEMLED32>0</OEMLED32>
<OEMDRO33>0.41771094</OEMDRO33>
<OEMLED33>0</OEMLED33>
<OEMDRO34>150.</OEMDRO34>
<OEMLED34>0</OEMLED34>
<OEMDRO35>0.1</OEMDRO35>
<OEMLED35>0</OEMLED35>
<OEMDRO36>0.</OEMDRO36>
<OEMLED36>0</OEMLED36>
<OEMDRO37>0.</OEMDRO37>
<OEMLED37>0</OEMLED37>
<OEMDRO38>0.</OEMDRO38>
<OEMLED38>0</OEMLED38>
<OEMDRO39>0.</OEMDRO39>
<OEMLED39>0</OEMLED39>
<OEMDRO40>0.</OEMDRO40>
<OEMLED40>0</OEMLED40>
<OEMDRO41>0.</OEMDRO41>
<OEMLED41>0</OEMLED41>
<OEMDRO42>0.</OEMDRO42>
<OEMLED42>0</OEMLED42>
<OEMDRO43>0.</OEMDRO43>
<OEMLED43>0</OEMLED43>
<OEMDRO44>0.</OEMDRO44>
<OEMLED44>0</OEMLED44>
<OEMDRO45>0.</OEMDRO45>
<OEMLED45>0</OEMLED45>
<OEMDRO46>0.</OEMDRO46>
<OEMLED46>0</OEMLED46>
<OEMDRO47>0.</OEMDRO47>
<OEMLED47>0</OEMLED47>
<OEMDRO48>0.</OEMDRO48>
<OEMLED48>0</OEMLED48>
<OEMDRO49>0.</OEMDRO49>
<OEMLED49>0</OEMLED49>
<OEMDRO50>0.</OEMDRO50>
<OEMLED50>0</OEMLED50>
<OEMDRO51>0.</OEMDRO51>
<OEMLED51>0</OEMLED51>
<OEMDRO52>0.</OEMDRO52>
<OEMLED52>0</OEMLED52>
<OEMDRO53>0.</OEMDRO53>
<OEMLED53>0</OEMLED53>
<OEMDRO54>0.</OEMDRO54>
<OEMLED54>0</OEMLED54>
<OEMDRO55>0.</OEMDRO55>
<OEMLED55>0</OEMLED55>
<OEMDRO56>0.</OEMDRO56>
<OEMLED56>0</OEMLED56>
<OEMDRO57>0.</OEMDRO57>
<OEMLED57>0</OEMLED57>
<OEMDRO58>0.</OEMDRO58>
<OEMLED58>0</OEMLED58>
<OEMDRO59>0.</OEMDRO59>
<OEMLED59>0</OEMLED59>
<OEMDRO60>0.</OEMDRO60>
<OEMLED60>0</OEMLED60>
<OEMDRO61>0.</OEMDRO61>
<OEMLED61>0</OEMLED61>
<OEMDRO62>0.</OEMDRO62>
<OEMLED62>0</OEMLED62>
<OEMDRO63>0.</OEMDRO63>
<OEMLED63>0</OEMLED63>
<OEMDRO64>0.</OEMDRO64>
<OEMLED64>0</OEMLED64>
<OEMDRO65>0.</OEMDRO65>
<OEMLED65>0</OEMLED65>
<OEMDRO66>0.</OEMDRO66>
<OEMLED66>0</OEMLED66>
<OEMDRO67>0.</OEMDRO67>
<OEMLED67>0</OEMLED67>
<OEMDRO68>0.</OEMDRO68>
<OEMLED68>0</OEMLED68>
<OEMDRO69>0.</OEMDRO69>
<OEMLED69>0</OEMLED69>
<OEMDRO70>0.</OEMDRO70>
<OEMLED70>0</OEMLED70>
<OEMDRO71>0.</OEMDRO71>
<OEMLED71>0</OEMLED71>
<OEMDRO72>0.</OEMDRO72>
<OEMLED72>0</OEMLED72>
<OEMDRO73>0.</OEMDRO73>
<OEMLED73>0</OEMLED73>
<OEMDRO74>0.</OEMDRO74>
<OEMLED74>0</OEMLED74>
<OEMDRO75>0.</OEMDRO75>
<OEMLED75>0</OEMLED75>
<OEMDRO76>0.</OEMDRO76>
<OEMLED76>0</OEMLED76>
<OEMDRO77>0.</OEMDRO77>
<OEMLED77>0</OEMLED77>
<OEMDRO78>0.</OEMDRO78>
<OEMLED78>0</OEMLED78>
<OEMDRO79>0.</OEMDRO79>
<OEMLED79>0</OEMLED79>
<OEMDRO80>1000.</OEMDRO80>
<OEMLED80>0</OEMLED80>
<OEMDRO81>2.</OEMDRO81>
<OEMLED81>0</OEMLED81>
<OEMDRO82>0.</OEMDRO82>
<OEMLED82>0</OEMLED82>
<OEMDRO83>0.</OEMDRO83>
<OEMLED83>0</OEMLED83>
<OEMDRO84>0.</OEMDRO84>
<OEMLED84>0</OEMLED84>
<OEMDRO85>0.</OEMDRO85>
<OEMLED85>0</OEMLED85>
<OEMDRO86>0.</OEMDRO86>
<OEMLED86>0</OEMLED86>
<OEMDRO87>0.</OEMDRO87>
<OEMLED87>0</OEMLED87>
<OEMDRO88>0.</OEMDRO88>
<OEMLED88>0</OEMLED88>
<OEMDRO89>0.</OEMDRO89>
<OEMLED89>0</OEMLED89>
<OEMDRO90>0.</OEMDRO90>
<OEMLED90>0</OEMLED90>
<OEMDRO91>0.</OEMDRO91>
<OEMLED91>0</OEMLED91>
<OEMDRO92>0.</OEMDRO92>
<OEMLED92>0</OEMLED92>
<OEMDRO93>0.</OEMDRO93>
<OEMLED93>0</OEMLED93>
<OEMDRO94>0.</OEMDRO94>
<OEMLED94>0</OEMLED94>
<OEMDRO95>0.</OEMDRO95>
<OEMLED95>0</OEMLED95>
<OEMDRO96>0.</OEMDRO96>
<OEMLED96>0</OEMLED96>
<OEMDRO97>0.</OEMDRO97>
<OEMLED97>0</OEMLED97>
<OEMDRO98>0.</OEMDRO98>
<OEMLED98>0</OEMLED98>
<OEMDRO99>0.</OEMDRO99>
<OEMLED99>0</OEMLED99>
<OEMDRO100>0.</OEMDRO100>
<OEMLED100>0</OEMLED100>
<OEMDRO101>0.</OEMDRO101>
<OEMLED101>0</OEMLED101>
<OEMDRO102>0.</OEMDRO102>
<OEMLED102>0</OEMLED102>
<OEMDRO103>0.</OEMDRO103>
<OEMLED103>0</OEMLED103>
<OEMDRO104>0.</OEMDRO104>
<OEMLED104>0</OEMLED104>
<OEMDRO105>0.</OEMDRO105>
<OEMLED105>0</OEMLED105>
<OEMDRO106>0.</OEMDRO106>
<OEMLED106>0</OEMLED106>
<OEMDRO107>0.</OEMDRO107>
<OEMLED107>0</OEMLED107>
<OEMDRO108>0.</OEMDRO108>
<OEMLED108>0</OEMLED108>
<OEMDRO109>0.</OEMDRO109>
<OEMLED109>0</OEMLED109>
<OEMDRO110>0.</OEMDRO110>
<OEMLED110>0</OEMLED110>
<OEMDRO111>0.</OEMDRO111>
<OEMLED111>0</OEMLED111>
<OEMDRO112>0.</OEMDRO112>
<OEMLED112>0</OEMLED112>
<OEMDRO113>0.</OEMDRO113>
<OEMLED113>0</OEMLED113>
<OEMDRO114>0.</OEMDRO114>
<OEMLED114>0</OEMLED114>
<OEMDRO115>0.</OEMDRO115>
<OEMLED115>0</OEMLED115>
<OEMDRO116>0.</OEMDRO116>
<OEMLED116>0</OEMLED116>
<OEMDRO117>0.</OEMDRO117>
<OEMLED117>0</OEMLED117>
<OEMDRO118>0.</OEMDRO118>
<OEMLED118>0</OEMLED118>
<OEMDRO119>0.</OEMDRO119>
<OEMLED119>0</OEMLED119>
<OEMDRO120>0.</OEMDRO120>
<OEMLED120>0</OEMLED120>
<OEMDRO121>0.</OEMDRO121>
<OEMLED121>0</OEMLED121>
<OEMDRO122>0.</OEMDRO122>
<OEMLED122>0</OEMLED122>
<OEMDRO123>0.</OEMDRO123>
<OEMLED123>0</OEMLED123>
<OEMDRO124>0.</OEMDRO124>
<OEMLED124>0</OEMLED124>
<OEMDRO125>0.</OEMDRO125>
<OEMLED125>0</OEMLED125>
<OEMDRO126>0.</OEMDRO126>
<OEMLED126>0</OEMLED126>
<OEMDRO127>0.</OEMDRO127>
<OEMLED127>0</OEMLED127>
<OEMDRO128>0.</OEMDRO128>
<OEMLED128>0</OEMLED128>
<OEMDRO129>0.</OEMDRO129>
<OEMLED129>0</OEMLED129>
<OEMDRO130>0.</OEMDRO130>
<OEMLED130>0</OEMLED130>
<OEMDRO131>0.</OEMDRO131>
<OEMLED131>0</OEMLED131>
<OEMDRO132>0.</OEMDRO132>
<OEMLED132>0</OEMLED132>
<OEMDRO133>0.</OEMDRO133>
<OEMLED133>0</OEMLED133>
<OEMDRO134>0.</OEMDRO134>
<OEMLED134>0</OEMLED134>
<OEMDRO135>0.</OEMDRO135>
<OEMLED135>0</OEMLED135>
<OEMDRO136>0.</OEMDRO136>
<OEMLED136>0</OEMLED136>
<OEMDRO137>0.</OEMDRO137>
<OEMLED137>0</OEMLED137>
<OEMDRO138>0.</OEMDRO138>
<OEMLED138>0</OEMLED138>
<OEMDRO139>0.</OEMDRO139>
<OEMLED139>0</OEMLED139>
<OEMDRO140>0.</OEMDRO140>
<OEMLED140>0</OEMLED140>
<OEMDRO141>0.</OEMDRO141>
<OEMLED141>0</OEMLED141>
<OEMDRO142>0.</OEMDRO142>
<OEMLED142>0</OEMLED142>
<OEMDRO143>0.</OEMDRO143>
<OEMLED143>0</OEMLED143>
<OEMDRO144>0.</OEMDRO144>
<OEMLED144>0</OEMLED144>
<OEMDRO145>0.</OEMDRO145>
<OEMLED145>0</OEMLED145>
<OEMDRO146>0.</OEMDRO146>
<OEMLED146>0</OEMLED146>
<OEMDRO147>0.</OEMDRO147>
<OEMLED147>0</OEMLED147>
<OEMDRO148>0.</OEMDRO148>
<OEMLED148>0</OEMLED148>
<OEMDRO149>0.</OEMDRO149>
<OEMLED149>0</OEMLED149>
<OEMDRO150>0.</OEMDRO150>
<OEMLED150>0</OEMLED150>
<OEMDRO151>0.</OEMDRO151>
<OEMLED151>0</OEMLED151>
<OEMDRO152>0.</OEMDRO152>
<OEMLED152>0</OEMLED152>
<OEMDRO153>0.</OEMDRO153>
<OEMLED153>0</OEMLED153>
<OEMDRO154>0.</OEMDRO154>
<OEMLED154>0</OEMLED154>
<OEMDRO155>0.</OEMDRO155>
<OEMLED155>0</OEMLED155>
<OEMDRO156>0.</OEMDRO156>
<OEMLED156>0</OEMLED156>
<OEMDRO157>0.</OEMDRO157>
<OEMLED157>0</OEMLED157>
<OEMDRO158>0.</OEMDRO158>
<OEMLED158>0</OEMLED158>
<OEMDRO159>0.</OEMDRO159>
<OEMLED159>0</OEMLED159>
<OEMDRO160>0.</OEMDRO160>
<OEMLED160>0</OEMLED160>
<OEMDRO161>0.</OEMDRO161>
<OEMLED161>0</OEMLED161>
<OEMDRO162>0.</OEMDRO162>
<OEMLED162>0</OEMLED162>
<OEMDRO163>0.</OEMDRO163>
<OEMLED163>0</OEMLED163>
<OEMDRO164>0.</OEMDRO164>
<OEMLED164>0</OEMLED164>
<OEMDRO165>0.</OEMDRO165>
<OEMLED165>0</OEMLED165>
<OEMDRO166>0.</OEMDRO166>
<OEMLED166>0</OEMLED166>
<OEMDRO167>0.</OEMDRO167>
<OEMLED167>0</OEMLED167>
<OEMDRO168>0.</OEMDRO168>
<OEMLED168>0</OEMLED168>
<OEMDRO169>0.</OEMDRO169>
<OEMLED169>0</OEMLED169>
<OEMDRO170>0.</OEMDRO170>
<OEMLED170>0</OEMLED170>
<OEMDRO171>0.</OEMDRO171>
<OEMLED171>0</OEMLED171>
<OEMDRO172>0.</OEMDRO172>
<OEMLED172>0</OEMLED172>
<OEMDRO173>0.</OEMDRO173>
<OEMLED173>0</OEMLED173>
<OEMDRO174>0.</OEMDRO174>
<OEMLED174>0</OEMLED174>
<OEMDRO175>0.</OEMDRO175>
<OEMLED175>0</OEMLED175>
<OEMDRO176>0.</OEMDRO176>
<OEMLED176>0</OEMLED176>
<OEMDRO177>0.</OEMDRO177>
<OEMLED177>0</OEMLED177>
<OEMDRO178>0.</OEMDRO178>
<OEMLED178>0</OEMLED178>
<OEMDRO179>0.</OEMDRO179>
<OEMLED179>0</OEMLED179>
<OEMDRO180>0.</OEMDRO180>
<OEMLED180>0</OEMLED180>
<OEMDRO181>0.</OEMDRO181>
<OEMLED181>0</OEMLED181>
<OEMDRO182>0.</OEMDRO182>
<OEMLED182>0</OEMLED182>
<OEMDRO183>0.</OEMDRO183>
<OEMLED183>0</OEMLED183>
<OEMDRO184>0.</OEMDRO184>
<OEMLED184>0</OEMLED184>
<OEMDRO185>0.</OEMDRO185>
<OEMLED185>0</OEMLED185>
<OEMDRO186>0.</OEMDRO186>
<OEMLED186>0</OEMLED186>
<OEMDRO187>0.</OEMDRO187>
<OEMLED187>0</OEMLED187>
<OEMDRO188>0.</OEMDRO188>
<OEMLED188>0</OEMLED188>
<OEMDRO189>0.</OEMDRO189>
<OEMLED189>0</OEMLED189>
<OEMDRO190>0.</OEMDRO190>
<OEMLED190>0</OEMLED190>
<OEMDRO191>0.</OEMDRO191>
<OEMLED191>0</OEMLED191>
<OEMDRO192>0.</OEMDRO192>
<OEMLED192>0</OEMLED192>
<OEMDRO193>0.</OEMDRO193>
<OEMLED193>0</OEMLED193>
<OEMDRO194>0.</OEMDRO194>
<OEMLED194>0</OEMLED194>
<OEMDRO195>0.</OEMDRO195>
<OEMLED195>0</OEMLED195>
<OEMDRO196>0.</OEMDRO196>
<OEMLED196>0</OEMLED196>
<OEMDRO197>0.</OEMDRO197>
<OEMLED197>0</OEMLED197>
<OEMDRO198>0.</OEMDRO198>
<OEMLED198>0</OEMLED198>
<OEMDRO199>0.</OEMDRO199>
<OEMLED199>0</OEMLED199>
<OEMDRO200>0.</OEMDRO200>
<OEMLED200>0</OEMLED200>
<OEMDRO201>0.</OEMDRO201>
<OEMLED201>0</OEMLED201>
<OEMDRO202>0.</OEMDRO202>
<OEMLED202>0</OEMLED202>
<OEMDRO203>0.</OEMDRO203>
<OEMLED203>0</OEMLED203>
<OEMDRO204>0.</OEMDRO204>
<OEMLED204>0</OEMLED204>
<OEMDRO205>0.</OEMDRO205>
<OEMLED205>0</OEMLED205>
<OEMDRO206>0.</OEMDRO206>
<OEMLED206>0</OEMLED206>
<OEMDRO207>0.</OEMDRO207>
<OEMLED207>0</OEMLED207>
<OEMDRO208>0.</OEMDRO208>
<OEMLED208>0</OEMLED208>
<OEMDRO209>0.</OEMDRO209>
<OEMLED209>0</OEMLED209>
<OEMDRO210>0.</OEMDRO210>
<OEMLED210>0</OEMLED210>
<OEMDRO211>0.</OEMDRO211>
<OEMLED211>0</OEMLED211>
<OEMDRO212>0.</OEMDRO212>
<OEMLED212>0</OEMLED212>
<OEMDRO213>0.</OEMDRO213>
<OEMLED213>0</OEMLED213>
<OEMDRO214>0.</OEMDRO214>
<OEMLED214>0</OEMLED214>
<OEMDRO215>0.</OEMDRO215>
<OEMLED215>0</OEMLED215>
<OEMDRO216>0.</OEMDRO216>
<OEMLED216>0</OEMLED216>
<OEMDRO217>0.</OEMDRO217>
<OEMLED217>0</OEMLED217>
<OEMDRO218>0.</OEMDRO218>
<OEMLED218>0</OEMLED218>
<OEMDRO219>0.</OEMDRO219>
<OEMLED219>0</OEMLED219>
<OEMDRO220>0.</OEMDRO220>
<OEMLED220>0</OEMLED220>
<OEMDRO221>0.</OEMDRO221>
<OEMLED221>0</OEMLED221>
<OEMDRO222>0.</OEMDRO222>
<OEMLED222>0</OEMLED222>
<OEMDRO223>0.</OEMDRO223>
<OEMLED223>0</OEMLED223>
<OEMDRO224>0.</OEMDRO224>
<OEMLED224>0</OEMLED224>
<OEMDRO225>0.</OEMDRO225>
<OEMLED225>0</OEMLED225>
<OEMDRO226>0.</OEMDRO226>
<OEMLED226>0</OEMLED226>
<OEMDRO227>0.</OEMDRO227>
<OEMLED227>0</OEMLED227>
<OEMDRO228>0.</OEMDRO228>
<OEMLED228>0</OEMLED228>
<OEMDRO229>0.</OEMDRO229>
<OEMLED229>0</OEMLED229>
<OEMDRO230>0.</OEMDRO230>
<OEMLED230>0</OEMLED230>
<OEMDRO231>0.</OEMDRO231>
<OEMLED231>0</OEMLED231>
<OEMDRO232>0.</OEMDRO232>
<OEMLED232>0</OEMLED232>
<OEMDRO233>0.</OEMDRO233>
<OEMLED233>0</OEMLED233>
<OEMDRO234>0.</OEMDRO234>
<OEMLED234>0</OEMLED234>
<OEMDRO235>0.</OEMDRO235>
<OEMLED235>0</OEMLED235>
<OEMDRO236>0.</OEMDRO236>
<OEMLED236>0</OEMLED236>
<OEMDRO237>0.</OEMDRO237>
<OEMLED237>0</OEMLED237>
<OEMDRO238>0.</OEMDRO238>
<OEMLED238>0</OEMLED238>
<OEMDRO239>0.</OEMDRO239>
<OEMLED239>0</OEMLED239>
<OEMDRO240>10.</OEMDRO240>
<OEMLED240>0</OEMLED240>
<OEMDRO241>9.5</OEMDRO241>
<OEMLED241>0</OEMLED241>
<OEMDRO242>10.</OEMDRO242>
<OEMLED242>0</OEMLED242>
<OEMDRO243>10.</OEMDRO243>
<OEMLED243>0</OEMLED243>
<OEMDRO244>5.e-002</OEMDRO244>
<OEMLED244>0</OEMLED244>
<OEMDRO245>0.</OEMDRO245>
<OEMLED245>0</OEMLED245>
<OEMDRO246>2.5e-002</OEMDRO246>
<OEMLED246>0</OEMLED246>
<OEMDRO247>0.1</OEMDRO247>
<OEMLED247>0</OEMLED247>
<OEMDRO248>0.1</OEMDRO248>
<OEMLED248>0</OEMLED248>
<OEMDRO249>29.</OEMDRO249>
<OEMLED249>0</OEMLED249>
<OEMDRO250>0.</OEMDRO250>
<OEMLED250>0</OEMLED250>
<OEMDRO251>0.</OEMDRO251>
<OEMLED251>0</OEMLED251>
<OEMDRO252>0.</OEMDRO252>
<OEMLED252>0</OEMLED252>
<OEMDRO253>0.</OEMDRO253>
<OEMLED253>0</OEMLED253>
<OEMDRO254>0.</OEMDRO254>
<OEMLED254>0</OEMLED254>
<OEMDRO255>0.</OEMDRO255>
<OEMLED255>0</OEMLED255>
<LiftLevel>-6.2774386e+066</LiftLevel>
<LiftAngle>-6.2774386e+066</LiftAngle>
<InhibitDepth>0.</InhibitDepth>
<LaserXGrid>0.</LaserXGrid>
<LaserYGrid>0.</LaserYGrid>
<JogInc0>1.</JogInc0>
<JogInc1>0.1</JogInc1>
<JogInc2>1.e-002</JogInc2>
<JogInc3>1.e-003</JogInc3>
<JogInc4>1.e-004</JogInc4>
<JogInc5>1.</JogInc5>
<JogInc6>0.1</JogInc6>
<JogInc7>1.e-002</JogInc7>
<JogInc8>1.e-003</JogInc8>
<JogInc9>1.e-004</JogInc9>
<THCSpeed>-6.2774386e+066</THCSpeed>
<BlendFactor>180.</BlendFactor>
<M0RefHome>0</M0RefHome>
<M1RefHome>0</M1RefHome>
<M2RefHome>0</M2RefHome>
<M3RefHome>0</M3RefHome>
<M4RefHome>0</M4RefHome>
<M5RefHome>0</M5RefHome>
<InitAllResets>0</InitAllResets>
<AutoScreens>0</AutoScreens>
<MRU10>C:\Users\4StepsAhead BV\Desktop\frank_4.txt</MRU10>
<MRU9>C:\Users\4StepsAhead BV\Desktop\frank_5.txt</MRU9>
<MRU6>C:\Users\4StepsAhead BV\Desktop\Das Special Products\Membraandop radiaal nadraaien.txt</MRU6>
<MRU2>C:\Users\4StepsAhead BV\Desktop\Das Special Products\Membraandop\Membraandop radiaal.txt</MRU2>
<MRU1>C:\Users\4StepsAhead BV\Desktop\Das Special Products\Membraandop\Membraandop axiaal nadraaien.txt</MRU1>
<ListKey>999</ListKey>
<OEM1>-1</OEM1>
<OEM2>-1</OEM2>
<OEM3>-1</OEM3>
<OEM4>-1</OEM4>
<OEM5>-1</OEM5>
<OEM6>-1</OEM6>
<FeedInc>5.</FeedInc>
<FirstRun>1</FirstRun>
<SpinDelayCW>1.</SpinDelayCW>
<SpinDelayCCW>1.</SpinDelayCCW>
<SpinDownCW>1.</SpinDownCW>
<SpinDownCCW>1.</SpinDownCCW>
<LSPEED1>0</LSPEED1>
<LSPEED2>0</LSPEED2>
<LSPEED3>0</LSPEED3>
<LSPEED4>0</LSPEED4>
<SpinClosed>1</SpinClosed>
<Vel6>455.1</Vel6>
<Acc6>570.</Acc6>
<Steps6>2000</Steps6>
<PlasmaMode>0</PlasmaMode>
<NoAngle>1</NoAngle>
<IndexDebounce>100</IndexDebounce>
<DwellinMilli>0</DwellinMilli>
<SpinP>0.5</SpinP>
<SpinI>0.2</SpinI>
<SpinD>0.5</SpinD>
<JogFollow>0</JogFollow>
<ToolFlip>0</ToolFlip>
<DepthLastPass>0.</DepthLastPass>
<InFeed>29.5</InFeed>
<Spring>1.</Spring>
<MinDepth>1.e-003</MinDepth>
<XClear>0.1</XClear>
<Chamfer>0.</Chamfer>
<DepthFirstPass>0.1</DepthFirstPass>
<ModBus>0</ModBus>
<Port2Input>0</Port2Input>
<LastWizard>c:\Program Files\MyProjects\Mach4\TurnAddons\Simple Threading (Lathe)\threading (lathe).set</LastWizard>
<ChargeAlwaysOn>0</ChargeAlwaysOn>
<JogMode2>0</JogMode2>
<EncJogAxis2>2</EncJogAxis2>
<TaperRatio>2.</TaperRatio>
<Dist0>8.7e+004</Dist0>
<Dist1>1.4e+002</Dist1>
<Dist2>3.5e+004</Dist2>
<Dist3>0.</Dist3>
<Dist4>0.</Dist4>
<Dist5>0.</Dist5>
<SecondsOn>308325</SecondsOn>
<Z25D>0</Z25D>
<MinPerPass>0.1</MinPerPass>
<CutType>0</CutType>
<InfeedType>0</InfeedType>
<StockSize>20</StockSize>
<ShowSolid>1</ShowSolid>
<MatRed>0.</MatRed>
<MatGreen>0.1</MatGreen>
<MatBlue>0.1</MatBlue>
<MRU8>C:\Users\4StepsAhead BV\Desktop\Das Special Products\Membraandop radiaal.txt</MRU8>
<MRU7>C:\Users\4StepsAhead BV\Desktop\Das Special Products\Membraandop axiaal nadraaien.txt</MRU7>
<Dig4Axis>0</Dig4Axis>
<DigLetter>0</DigLetter>
<SerialType>0</SerialType>
<SpinAverage>1</SpinAverage>
<DXFDir>C:\Documents and Settings\Art\Desktop\TURNTEST.dxf</DXFDir>
<DXFNOZS>0</DXFNOZS>
<DXFAsDrawn>0</DXFAsDrawn>
<DXFLathe>1</DXFLathe>
<DXFReturn>0</DXFReturn>
<DXFOpto>0</DXFOpto>
<NoTHC>0</NoTHC>
<DXFPlasma>0</DXFPlasma>
<DXFClear>1.</DXFClear>
<DXFTol>0.1</DXFTol>
<DXFTool0>0</DXFTool0>
<DXFSpindle0>1000</DXFSpindle0>
<DXFDepth0>0.</DXFDepth0>
<DXFPlunge0>1.</DXFPlunge0>
<DXFFeed0>1.</DXFFeed0>
<DXFTool1>0</DXFTool1>
<DXFSpindle1>1000</DXFSpindle1>
<DXFDepth1>0.</DXFDepth1>
<DXFPlunge1>1.</DXFPlunge1>
<DXFFeed1>1.</DXFFeed1>
<MRU4>C:\Users\4StepsAhead BV\Desktop\test.tap</MRU4>
<RapidFeed>1.e+003</RapidFeed>
<DXFTool2>0</DXFTool2>
<DXFSpindle2>0</DXFSpindle2>
<DXFDepth2>0.</DXFDepth2>
<DXFPlunge2>0.</DXFPlunge2>
<DXFFeed2>0.</DXFFeed2>
<Formula0>x</Formula0>
<Formula1>y</Formula1>
<Formula2>z</Formula2>
<Formula3>a</Formula3>
<Formula4>b</Formula4>
<Formula5>c</Formula5>
<Formular>0</Formular>
<ZClear>0.1</ZClear>
<CutDepth>0.1</CutDepth>
<LaserAGrid>0.</LaserAGrid>
<JogVelocity>0</JogVelocity>
<XCLength>1.2e+003</XCLength>
<YCLength>1.2e+003</YCLength>
<ZCLength>1.2e+003</ZCLength>
<MPGVel0>1.e+002</MPGVel0>
<MPGVel1>1.e+002</MPGVel1>
<MPGVel2>1.e+002</MPGVel2>
<MPGVel3>1.e+002</MPGVel3>
<MPGVel4>9.e+003</MPGVel4>
<XMapOn>0</XMapOn>
<YMapOn>0</YMapOn>
<ZMapOn>0</ZMapOn>
<INIT>G80</INIT>
<RapidOverRide>0</RapidOverRide>
<LaserStandby>0</LaserStandby>
<RaiseLower>0</RaiseLower>
<OEMDUAL>0</OEMDUAL>
<IncBuffer>5</IncBuffer>
<Tool>0</Tool>
<MRU3>C:\Users\4StepsAhead BV\Desktop\afsteken.txt</MRU3>
<UseSafeZ>0</UseSafeZ>
<TorchOff>0</TorchOff>
<MPGVel5>1.e+002</MPGVel5>
<MPGVel6>1.e+002</MPGVel6>
<AdvancedComp>1</AdvancedComp>
<Sherline>0</Sherline>
<GExt>*.txt</GExt>
<MRU5>C:\Users\4StepsAhead BV\Desktop\Das Special Products\Membraandop axiaal.txt</MRU5>
<ModSpindleCal>1.638e+004</ModSpindleCal>
<ModSpindleOn>0</ModSpindleOn>
<ModSpindleReg>64</ModSpindleReg>
<Flash>1</Flash>
<ImmediateOff>0</ImmediateOff>
<ByPassFeed>1.e+003</ByPassFeed>
<ToolPost>1</ToolPost>
<ToolPostOffset>0.</ToolPostOffset>
<ShuttleAccel>2048</ShuttleAccel>
<nModBusReg>0</nModBusReg>
<ModBusRegOn>0</ModBusRegOn>
<Enc0>-1.832e+005</Enc0>
<Enc1>0.</Enc1>
<Enc2>-2.096e+005</Enc2>
<Enc3>0.</Enc3>
<Homann>0</Homann>
<VelMode>0</VelMode>
<VelPer>5.</VelPer>
<PanelOut>272</PanelOut>
<OEM7>-1</OEM7>
<OEM8>-1</OEM8>
<OEM9>-1</OEM9>
<OEM10>-1</OEM10>
<OEM11>-1</OEM11>
<OEM12>-1</OEM12>
<OEM13>-1</OEM13>
<OEM14>-1</OEM14>
<OEM15>-1</OEM15>
<PlasmaHome>0</PlasmaHome>
<VelPer1>5.</VelPer1>
<VelPer2>5.</VelPer2>
<IGNORETOOL>1</IGNORETOOL>
<MPGFeed>1.e+002</MPGFeed>
<MacroPump>0</MacroPump>
<BitPack1>0</BitPack1>
<BitPack1Reg>16</BitPack1Reg>
<OverMode2>0</OverMode2>
<BitPackOut>0</BitPackOut>
<BitPackOutReg>16</BitPackOutReg>
<LaserPort>1</LaserPort>
<LaserBaud>9600</LaserBaud>
<LaserStops>1</LaserStops>
<LaserData>1</LaserData>
<LaserInit>></LaserInit>
<LaserCommand>></LaserCommand>
<LookAhead>20</LookAhead>
<WatchDog>1</WatchDog>
<Plane>0</Plane>
<MPG1>0</MPG1>
<MPG2>0</MPG2>
<HotKeysPersist>0</HotKeysPersist>
<HoldInput1>0</HoldInput1>
<M3s>91</M3s>
<UseCR>0</UseCR>
<UseSLS>0</UseSLS>
<Serial>0</Serial>
<Input36Active>0</Input36Active>
<Input36Port>0</Input36Port>
<Input36Pin>0</Input36Pin>
<Input36Neg>0</Input36Neg>
<Input36Emulated>0</Input36Emulated>
<Input36EmuKey>0</Input36EmuKey>
<Input37Active>0</Input37Active>
<Input37Port>0</Input37Port>
<Input37Pin>0</Input37Pin>
<Input37Neg>0</Input37Neg>
<Input37Emulated>0</Input37Emulated>
<Input37EmuKey>0</Input37EmuKey>
<Input38Active>0</Input38Active>
<Input38Port>0</Input38Port>
<Input38Pin>0</Input38Pin>
<Input38Neg>0</Input38Neg>
<Input38Emulated>0</Input38Emulated>
<Input38EmuKey>0</Input38EmuKey>
<Input39Active>0</Input39Active>
<Input39Port>0</Input39Port>
<Input39Pin>0</Input39Pin>
<Input39Neg>0</Input39Neg>
<Input39Emulated>0</Input39Emulated>
<Input39EmuKey>0</Input39EmuKey>
<Input40Active>0</Input40Active>
<Input40Port>0</Input40Port>
<Input40Pin>0</Input40Pin>
<Input40Neg>0</Input40Neg>
<Input40Emulated>0</Input40Emulated>
<Input40EmuKey>0</Input40EmuKey>
<Input41Active>0</Input41Active>
<Input41Port>0</Input41Port>
<Input41Pin>0</Input41Pin>
<Input41Neg>0</Input41Neg>
<Input41Emulated>0</Input41Emulated>
<Input41EmuKey>0</Input41EmuKey>
<Input42Active>0</Input42Active>
<Input42Port>0</Input42Port>
<Input42Pin>0</Input42Pin>
<Input42Neg>0</Input42Neg>
<Input42Emulated>0</Input42Emulated>
<Input42EmuKey>0</Input42EmuKey>
<Input43Active>0</Input43Active>
<Input43Port>0</Input43Port>
<Input43Pin>0</Input43Pin>
<Input43Neg>0</Input43Neg>
<Input43Emulated>0</Input43Emulated>
<Input43EmuKey>0</Input43EmuKey>
<Input44Active>0</Input44Active>
<Input44Port>0</Input44Port>
<Input44Pin>0</Input44Pin>
<Input44Neg>0</Input44Neg>
<Input44Emulated>0</Input44Emulated>
<Input44EmuKey>0</Input44EmuKey>
<Input45Active>0</Input45Active>
<Input45Port>0</Input45Port>
<Input45Pin>0</Input45Pin>
<Input45Neg>0</Input45Neg>
<Input45Emulated>0</Input45Emulated>
<Input45EmuKey>0</Input45EmuKey>
<Input46Active>0</Input46Active>
<Input46Port>0</Input46Port>
<Input46Pin>0</Input46Pin>
<Input46Neg>0</Input46Neg>
<Input46Emulated>0</Input46Emulated>
<Input46EmuKey>0</Input46EmuKey>
<Input47Active>0</Input47Active>
<Input47Port>0</Input47Port>
<Input47Pin>0</Input47Pin>
<Input47Neg>0</Input47Neg>
<Input47Emulated>0</Input47Emulated>
<Input47EmuKey>0</Input47EmuKey>
<Input48Active>0</Input48Active>
<Input48Port>0</Input48Port>
<Input48Pin>0</Input48Pin>
<Input48Neg>0</Input48Neg>
<Input48Emulated>0</Input48Emulated>
<Input48EmuKey>0</Input48EmuKey>
<Input49Active>0</Input49Active>
<Input49Port>0</Input49Port>
<Input49Pin>0</Input49Pin>
<Input49Neg>0</Input49Neg>
<Input49Emulated>0</Input49Emulated>
<Input49EmuKey>0</Input49EmuKey>
<Input50Active>0</Input50Active>
<Input50Port>0</Input50Port>
<Input50Pin>0</Input50Pin>
<Input50Neg>0</Input50Neg>
<Input50Emulated>0</Input50Emulated>
<Input50EmuKey>0</Input50EmuKey>
<Input51Active>0</Input51Active>
<Input51Port>0</Input51Port>
<Input51Pin>0</Input51Pin>
<Input51Neg>0</Input51Neg>
<Input51Emulated>0</Input51Emulated>
<Input51EmuKey>0</Input51EmuKey>
<Input52Active>0</Input52Active>
<Input52Port>0</Input52Port>
<Input52Pin>0</Input52Pin>
<Input52Neg>0</Input52Neg>
<Input52Emulated>0</Input52Emulated>
<Input52EmuKey>0</Input52EmuKey>
<TORCHVON>0</TORCHVON>
<TORCHVOLTS>200</TORCHVOLTS>
<HWSAFE>1</HWSAFE>
<ShortRot>1</ShortRot>
<DefDir>C:\Mach3</DefDir>
<NewPath>0</NewPath>
<SafeZStop>0</SafeZStop>
<SafeZType>0</SafeZType>
<UseDiam>0</UseDiam>
<ToolLines>0</ToolLines>
<NURBS>1</NURBS>
<ToolPersist>0</ToolPersist>
<KeepRef>0</KeepRef>
<TurnRevArc>1</TurnRevArc>
<HiRes>0</HiRes>
<DelinChar>12</DelinChar>
<Rot360>0</Rot360>
<UDP>0</UDP>
<DROFont>Arial</DROFont>
<LabelFont>Arial</LabelFont>
<CodeFont>Arial</CodeFont>
<PierceDelay>1.</PierceDelay>
<VelPer3>5.</VelPer3>
<TouchX>0.</TouchX>
<G20X>0.</G20X>
<G20Y>0.</G20Y>
<G20Z>0.</G20Z>
<G20A>0.</G20A>
<G20B>0.</G20B>
<G20C>0.</G20C>
<FrontRear>0.</FrontRear>
<SPINREV1>0</SPINREV1>
<SPINREV2>0</SPINREV2>
<SPINREV3>0</SPINREV3>
<SPINREV4>0</SPINREV4>
<SPEED5>25000</SPEED5>
<LSPEED5>0</LSPEED5>
<SPINREV5>0</SPINREV5>
<SPEED6>25000</SPEED6>
<LSPEED6>0</LSPEED6>
<SPINREV6>0</SPINREV6>
<SPEED7>25000</SPEED7>
<LSPEED7>0</LSPEED7>
<SPINREV7>0</SPINREV7>
<SPEED8>25000</SPEED8>
<LSPEED8>0</LSPEED8>
<SPINREV8>0</SPINREV8>
<SPEED9>25000</SPEED9>
<LSPEED9>0</LSPEED9>
<SPINREV9>0</SPINREV9>
<SPEED10>25000</SPEED10>
<LSPEED10>0</LSPEED10>
<SPINREV10>0</SPINREV10>
<SPEED11>25000</SPEED11>
<LSPEED11>0</LSPEED11>
<SPINREV11>0</SPINREV11>
<SPEED12>25000</SPEED12>
<LSPEED12>0</LSPEED12>
<SPINREV12>0</SPINREV12>
<SPEED13>25000</SPEED13>
<LSPEED13>0</LSPEED13>
<SPINREV13>0</SPINREV13>
<SPEED14>25000</SPEED14>
<LSPEED14>0</LSPEED14>
<SPINREV14>0</SPINREV14>
<SPEED15>25000</SPEED15>
<LSPEED15>0</LSPEED15>
<SPINREV15>0</SPINREV15>
<SPEED16>25000</SPEED16>
<LSPEED16>0</LSPEED16>
<SPINREV16>0</SPINREV16>
<SPEED17>25000</SPEED17>
<LSPEED17>0</LSPEED17>
<SPINREV17>0</SPINREV17>
<SPEED18>25000</SPEED18>
<LSPEED18>0</LSPEED18>
<SPINREV18>0</SPINREV18>
<SPEED19>25000</SPEED19>
<LSPEED19>0</LSPEED19>
<SPINREV19>0</SPINREV19>
<SPEED20>25000</SPEED20>
<LSPEED20>0</LSPEED20>
<SPINREV20>0</SPINREV20>
<SPEED21>25000</SPEED21>
<LSPEED21>0</LSPEED21>
<SPINREV21>0</SPINREV21>
<SPEED22>25000</SPEED22>
<LSPEED22>0</LSPEED22>
<SPINREV22>0</SPINREV22>
<SPEED23>25000</SPEED23>
<LSPEED23>0</LSPEED23>
<SPINREV23>0</SPINREV23>
<SPEED24>25000</SPEED24>
<LSPEED24>0</LSPEED24>
<SPINREV24>0</SPINREV24>
<SPEED25>25000</SPEED25>
<LSPEED25>0</LSPEED25>
<SPINREV25>0</SPINREV25>
<EncJogAxis1>0</EncJogAxis1>
<EncJogAxis3>2</EncJogAxis3>
<AutoCalcs>0</AutoCalcs>
<Converted>1</Converted>
<CVUseAngle>0</CVUseAngle>
<CVDegrees>0.</CVDegrees>
<M30SpinOff>1</M30SpinOff>
<Boxed>1</Boxed>
<ButtonFont>Arial</ButtonFont>
<OVSpinInc>10</OVSpinInc>
<Encoder0>-183150</Encoder0>
<Encoder4>0</Encoder4>
<Encoder5>0</Encoder5>
<Encoder6>0</Encoder6>
<Syskey1>1</Syskey1>
<Running>0</Running>
<LastUser>4StepsAhead B.V.</LastUser>
<M9After>0</M9After>
<DwellTrigger>0</DwellTrigger>
<IgnoreMacros>0</IgnoreMacros>
<ZBar>1</ZBar>
<ROTSOFT>1</ROTSOFT>
<PROBETLO>0</PROBETLO>
<SlaveHome>0</SlaveHome>
<LockFROs>1</LockFROs>
<JogHeat>0</JogHeat>
<KeyClick>0</KeyClick>
<THC5>0</THC5>
<M7Delay>0.</M7Delay>
<M8Delay>0.</M8Delay>
<ACLength>50</ACLength>
<BCLength>50</BCLength>
<CCLength>50</CCLength>
<AMapOn>0</AMapOn>
<BMapOn>0</BMapOn>
<CMapOn>0</CMapOn>
<SPINRATIO1>1.</SPINRATIO1>
<SPINRATIO2>1.</SPINRATIO2>
<SPINRATIO3>1.</SPINRATIO3>
<SPINRATIO4>1.</SPINRATIO4>
<SPINRATIO5>1.</SPINRATIO5>
<SPINRATIO6>1.</SPINRATIO6>
<SPINRATIO7>1.</SPINRATIO7>
<SPINRATIO8>1.</SPINRATIO8>
<SPINRATIO9>1.</SPINRATIO9>
<SPINRATIO10>1.</SPINRATIO10>
<SPINRATIO11>1.</SPINRATIO11>
<SPINRATIO12>1.</SPINRATIO12>
<SPINRATIO13>1.</SPINRATIO13>
<SPINRATIO14>1.</SPINRATIO14>
<SPINRATIO15>1.</SPINRATIO15>
<SPINRATIO16>1.</SPINRATIO16>
<SPINRATIO17>1.</SPINRATIO17>
<SPINRATIO18>1.</SPINRATIO18>
<SPINRATIO19>1.</SPINRATIO19>
<SPINRATIO20>1.</SPINRATIO20>
<SPINRATIO21>1.</SPINRATIO21>
<SPINRATIO22>1.</SPINRATIO22>
<SPINRATIO23>1.</SPINRATIO23>
<SPINRATIO24>1.</SPINRATIO24>
<SPINRATIO25>1.</SPINRATIO25>
<OEMDRO2_0>0.</OEMDRO2_0>
<OEMLED2_0>0</OEMLED2_0>
<OEMDRO2_1>0.</OEMDRO2_1>
<OEMLED2_1>0</OEMLED2_1>
<OEMDRO2_2>0.</OEMDRO2_2>
<OEMLED2_2>0</OEMLED2_2>
<OEMDRO2_3>0.</OEMDRO2_3>
<OEMLED2_3>0</OEMLED2_3>
<OEMDRO2_4>0.</OEMDRO2_4>
<OEMLED2_4>0</OEMLED2_4>
<OEMDRO2_5>0.</OEMDRO2_5>
<OEMLED2_5>0</OEMLED2_5>
<OEMDRO2_6>0.</OEMDRO2_6>
<OEMLED2_6>0</OEMLED2_6>
<OEMDRO2_7>0.</OEMDRO2_7>
<OEMLED2_7>0</OEMLED2_7>
<OEMDRO2_8>0.</OEMDRO2_8>
<OEMLED2_8>0</OEMLED2_8>
<OEMDRO2_9>0.</OEMDRO2_9>
<OEMLED2_9>0</OEMLED2_9>
<OEMDRO2_10>0.</OEMDRO2_10>
<OEMLED2_10>0</OEMLED2_10>
<OEMDRO2_11>0.</OEMDRO2_11>
<OEMLED2_11>0</OEMLED2_11>
<OEMDRO2_12>0.</OEMDRO2_12>
<OEMLED2_12>0</OEMLED2_12>
<OEMDRO2_13>0.</OEMDRO2_13>
<OEMLED2_13>0</OEMLED2_13>
<OEMDRO2_14>0.</OEMDRO2_14>
<OEMLED2_14>0</OEMLED2_14>
<OEMDRO2_15>0.</OEMDRO2_15>
<OEMLED2_15>0</OEMLED2_15>
<OEMDRO2_16>0.</OEMDRO2_16>
<OEMLED2_16>0</OEMLED2_16>
<OEMDRO2_17>0.</OEMDRO2_17>
<OEMLED2_17>0</OEMLED2_17>
<OEMDRO2_18>0.</OEMDRO2_18>
<OEMLED2_18>0</OEMLED2_18>
<OEMDRO2_19>0.</OEMDRO2_19>
<OEMLED2_19>0</OEMLED2_19>
<OEMDRO2_20>0.</OEMDRO2_20>
<OEMLED2_20>0</OEMLED2_20>
<OEMDRO2_21>0.</OEMDRO2_21>
<OEMLED2_21>0</OEMLED2_21>
<OEMDRO2_22>0.</OEMDRO2_22>
<OEMLED2_22>0</OEMLED2_22>
<OEMDRO2_23>0.</OEMDRO2_23>
<OEMLED2_23>0</OEMLED2_23>
<OEMDRO2_24>0.</OEMDRO2_24>
<OEMLED2_24>0</OEMLED2_24>
<OEMDRO2_25>0.</OEMDRO2_25>
<OEMLED2_25>0</OEMLED2_25>
<OEMDRO2_26>0.</OEMDRO2_26>
<OEMLED2_26>0</OEMLED2_26>
<OEMDRO2_27>0.</OEMDRO2_27>
<OEMLED2_27>0</OEMLED2_27>
<OEMDRO2_28>0.</OEMDRO2_28>
<OEMLED2_28>0</OEMLED2_28>
<OEMDRO2_29>0.</OEMDRO2_29>
<OEMLED2_29>0</OEMLED2_29>
<OEMDRO2_30>0.</OEMDRO2_30>
<OEMLED2_30>0</OEMLED2_30>
<OEMDRO2_31>0.</OEMDRO2_31>
<OEMLED2_31>0</OEMLED2_31>
<OEMDRO2_32>0.</OEMDRO2_32>
<OEMLED2_32>0</OEMLED2_32>
<OEMDRO2_33>0.</OEMDRO2_33>
<OEMLED2_33>0</OEMLED2_33>
<OEMDRO2_34>0.</OEMDRO2_34>
<OEMLED2_34>0</OEMLED2_34>
<OEMDRO2_35>0.</OEMDRO2_35>
<OEMLED2_35>0</OEMLED2_35>
<OEMDRO2_36>0.</OEMDRO2_36>
<OEMLED2_36>0</OEMLED2_36>
<OEMDRO2_37>0.</OEMDRO2_37>
<OEMLED2_37>0</OEMLED2_37>
<OEMDRO2_38>0.</OEMDRO2_38>
<OEMLED2_38>0</OEMLED2_38>
<OEMDRO2_39>0.</OEMDRO2_39>
<OEMLED2_39>0</OEMLED2_39>
<OEMDRO2_40>0.</OEMDRO2_40>
<OEMLED2_40>0</OEMLED2_40>
<OEMDRO2_41>0.</OEMDRO2_41>
<OEMLED2_41>0</OEMLED2_41>
<OEMDRO2_42>0.</OEMDRO2_42>
<OEMLED2_42>0</OEMLED2_42>
<OEMDRO2_43>0.</OEMDRO2_43>
<OEMLED2_43>0</OEMLED2_43>
<OEMDRO2_44>0.</OEMDRO2_44>
<OEMLED2_44>0</OEMLED2_44>
<OEMDRO2_45>0.</OEMDRO2_45>
<OEMLED2_45>0</OEMLED2_45>
<OEMDRO2_46>0.</OEMDRO2_46>
<OEMLED2_46>0</OEMLED2_46>
<OEMDRO2_47>0.</OEMDRO2_47>
<OEMLED2_47>0</OEMLED2_47>
<OEMDRO2_48>0.</OEMDRO2_48>
<OEMLED2_48>0</OEMLED2_48>
<OEMDRO2_49>0.</OEMDRO2_49>
<OEMLED2_49>0</OEMLED2_49>
<OEMDRO2_50>0.</OEMDRO2_50>
<OEMLED2_50>0</OEMLED2_50>
<OEMDRO2_51>0.</OEMDRO2_51>
<OEMLED2_51>0</OEMLED2_51>
<OEMDRO2_52>0.</OEMDRO2_52>
<OEMLED2_52>0</OEMLED2_52>
<OEMDRO2_53>0.</OEMDRO2_53>
<OEMLED2_53>0</OEMLED2_53>
<OEMDRO2_54>0.</OEMDRO2_54>
<OEMLED2_54>0</OEMLED2_54>
<OEMDRO2_55>0.</OEMDRO2_55>
<OEMLED2_55>0</OEMLED2_55>
<OEMDRO2_56>0.</OEMDRO2_56>
<OEMLED2_56>0</OEMLED2_56>
<OEMDRO2_57>0.</OEMDRO2_57>
<OEMLED2_57>0</OEMLED2_57>
<OEMDRO2_58>0.</OEMDRO2_58>
<OEMLED2_58>0</OEMLED2_58>
<OEMDRO2_59>0.</OEMDRO2_59>
<OEMLED2_59>0</OEMLED2_59>
<OEMDRO2_60>0.</OEMDRO2_60>
<OEMLED2_60>0</OEMLED2_60>
<OEMDRO2_61>0.</OEMDRO2_61>
<OEMLED2_61>0</OEMLED2_61>
<OEMDRO2_62>0.</OEMDRO2_62>
<OEMLED2_62>0</OEMLED2_62>
<OEMDRO2_63>0.</OEMDRO2_63>
<OEMLED2_63>0</OEMLED2_63>
<OEMDRO2_64>0.</OEMDRO2_64>
<OEMLED2_64>0</OEMLED2_64>
<OEMDRO2_65>0.</OEMDRO2_65>
<OEMLED2_65>0</OEMLED2_65>
<OEMDRO2_66>0.</OEMDRO2_66>
<OEMLED2_66>0</OEMLED2_66>
<OEMDRO2_67>0.</OEMDRO2_67>
<OEMLED2_67>0</OEMLED2_67>
<OEMDRO2_68>0.</OEMDRO2_68>
<OEMLED2_68>0</OEMLED2_68>
<OEMDRO2_69>0.</OEMDRO2_69>
<OEMLED2_69>0</OEMLED2_69>
<OEMDRO2_70>0.</OEMDRO2_70>
<OEMLED2_70>0</OEMLED2_70>
<OEMDRO2_71>0.</OEMDRO2_71>
<OEMLED2_71>0</OEMLED2_71>
<OEMDRO2_72>0.</OEMDRO2_72>
<OEMLED2_72>0</OEMLED2_72>
<OEMDRO2_73>0.</OEMDRO2_73>
<OEMLED2_73>0</OEMLED2_73>
<OEMDRO2_74>0.</OEMDRO2_74>
<OEMLED2_74>0</OEMLED2_74>
<OEMDRO2_75>0.</OEMDRO2_75>
<OEMLED2_75>0</OEMLED2_75>
<OEMDRO2_76>0.</OEMDRO2_76>
<OEMLED2_76>0</OEMLED2_76>
<OEMDRO2_77>0.</OEMDRO2_77>
<OEMLED2_77>0</OEMLED2_77>
<OEMDRO2_78>0.</OEMDRO2_78>
<OEMLED2_78>0</OEMLED2_78>
<OEMDRO2_79>0.</OEMDRO2_79>
<OEMLED2_79>0</OEMLED2_79>
<OEMDRO2_80>0.</OEMDRO2_80>
<OEMLED2_80>0</OEMLED2_80>
<OEMDRO2_81>0.</OEMDRO2_81>
<OEMLED2_81>0</OEMLED2_81>
<OEMDRO2_82>0.</OEMDRO2_82>
<OEMLED2_82>0</OEMLED2_82>
<OEMDRO2_83>0.</OEMDRO2_83>
<OEMLED2_83>0</OEMLED2_83>
<OEMDRO2_84>0.</OEMDRO2_84>
<OEMLED2_84>0</OEMLED2_84>
<OEMDRO2_85>0.</OEMDRO2_85>
<OEMLED2_85>0</OEMLED2_85>
<OEMDRO2_86>0.</OEMDRO2_86>
<OEMLED2_86>0</OEMLED2_86>
<OEMDRO2_87>0.</OEMDRO2_87>
<OEMLED2_87>0</OEMLED2_87>
<OEMDRO2_88>0.</OEMDRO2_88>
<OEMLED2_88>0</OEMLED2_88>
<OEMDRO2_89>0.</OEMDRO2_89>
<OEMLED2_89>0</OEMLED2_89>
<OEMDRO2_90>0.</OEMDRO2_90>
<OEMLED2_90>0</OEMLED2_90>
<OEMDRO2_91>0.</OEMDRO2_91>
<OEMLED2_91>0</OEMLED2_91>
<OEMDRO2_92>0.</OEMDRO2_92>
<OEMLED2_92>0</OEMLED2_92>
<OEMDRO2_93>0.</OEMDRO2_93>
<OEMLED2_93>0</OEMLED2_93>
<OEMDRO2_94>0.</OEMDRO2_94>
<OEMLED2_94>0</OEMLED2_94>
<OEMDRO2_95>0.</OEMDRO2_95>
<OEMLED2_95>0</OEMLED2_95>
<OEMDRO2_96>0.</OEMDRO2_96>
<OEMLED2_96>0</OEMLED2_96>
<OEMDRO2_97>0.</OEMDRO2_97>
<OEMLED2_97>0</OEMLED2_97>
<OEMDRO2_98>0.</OEMDRO2_98>
<OEMLED2_98>0</OEMLED2_98>
<OEMDRO2_99>0.</OEMDRO2_99>
<OEMLED2_99>0</OEMLED2_99>
<OEMDRO2_100>0.</OEMDRO2_100>
<OEMLED2_100>0</OEMLED2_100>
<OEMDRO2_101>0.</OEMDRO2_101>
<OEMLED2_101>0</OEMLED2_101>
<OEMDRO2_102>0.</OEMDRO2_102>
<OEMLED2_102>0</OEMLED2_102>
<OEMDRO2_103>0.</OEMDRO2_103>
<OEMLED2_103>0</OEMLED2_103>
<OEMDRO2_104>0.</OEMDRO2_104>
<OEMLED2_104>0</OEMLED2_104>
<OEMDRO2_105>0.</OEMDRO2_105>
<OEMLED2_105>0</OEMLED2_105>
<OEMDRO2_106>0.</OEMDRO2_106>
<OEMLED2_106>0</OEMLED2_106>
<OEMDRO2_107>0.</OEMDRO2_107>
<OEMLED2_107>0</OEMLED2_107>
<OEMDRO2_108>0.</OEMDRO2_108>
<OEMLED2_108>0</OEMLED2_108>
<OEMDRO2_109>0.</OEMDRO2_109>
<OEMLED2_109>0</OEMLED2_109>
<OEMDRO2_110>0.</OEMDRO2_110>
<OEMLED2_110>0</OEMLED2_110>
<OEMDRO2_111>0.</OEMDRO2_111>
<OEMLED2_111>0</OEMLED2_111>
<OEMDRO2_112>0.</OEMDRO2_112>
<OEMLED2_112>0</OEMLED2_112>
<OEMDRO2_113>0.</OEMDRO2_113>
<OEMLED2_113>0</OEMLED2_113>
<OEMDRO2_114>0.</OEMDRO2_114>
<OEMLED2_114>0</OEMLED2_114>
<OEMDRO2_115>0.</OEMDRO2_115>
<OEMLED2_115>0</OEMLED2_115>
<OEMDRO2_116>0.</OEMDRO2_116>
<OEMLED2_116>0</OEMLED2_116>
<OEMDRO2_117>0.</OEMDRO2_117>
<OEMLED2_117>0</OEMLED2_117>
<OEMDRO2_118>0.</OEMDRO2_118>
<OEMLED2_118>0</OEMLED2_118>
<OEMDRO2_119>0.</OEMDRO2_119>
<OEMLED2_119>0</OEMLED2_119>
<OEMDRO2_120>0.</OEMDRO2_120>
<OEMLED2_120>0</OEMLED2_120>
<OEMDRO2_121>0.</OEMDRO2_121>
<OEMLED2_121>0</OEMLED2_121>
<OEMDRO2_122>0.</OEMDRO2_122>
<OEMLED2_122>0</OEMLED2_122>
<OEMDRO2_123>0.</OEMDRO2_123>
<OEMLED2_123>0</OEMLED2_123>
<OEMDRO2_124>0.</OEMDRO2_124>
<OEMLED2_124>0</OEMLED2_124>
<OEMDRO2_125>0.</OEMDRO2_125>
<OEMLED2_125>0</OEMLED2_125>
<OEMDRO2_126>0.</OEMDRO2_126>
<OEMLED2_126>0</OEMLED2_126>
<OEMDRO2_127>0.</OEMDRO2_127>
<OEMLED2_127>0</OEMLED2_127>
<OEMDRO2_128>0.</OEMDRO2_128>
<OEMLED2_128>0</OEMLED2_128>
<OEMDRO2_129>0.</OEMDRO2_129>
<OEMLED2_129>0</OEMLED2_129>
<OEMDRO2_130>0.</OEMDRO2_130>
<OEMLED2_130>0</OEMLED2_130>
<OEMDRO2_131>0.</OEMDRO2_131>
<OEMLED2_131>0</OEMLED2_131>
<OEMDRO2_132>0.</OEMDRO2_132>
<OEMLED2_132>0</OEMLED2_132>
<OEMDRO2_133>0.</OEMDRO2_133>
<OEMLED2_133>0</OEMLED2_133>
<OEMDRO2_134>0.</OEMDRO2_134>
<OEMLED2_134>0</OEMLED2_134>
<OEMDRO2_135>0.</OEMDRO2_135>
<OEMLED2_135>0</OEMLED2_135>
<OEMDRO2_136>0.</OEMDRO2_136>
<OEMLED2_136>0</OEMLED2_136>
<OEMDRO2_137>0.</OEMDRO2_137>
<OEMLED2_137>0</OEMLED2_137>
<OEMDRO2_138>0.</OEMDRO2_138>
<OEMLED2_138>0</OEMLED2_138>
<OEMDRO2_139>0.</OEMDRO2_139>
<OEMLED2_139>0</OEMLED2_139>
<OEMDRO2_140>0.</OEMDRO2_140>
<OEMLED2_140>0</OEMLED2_140>
<OEMDRO2_141>0.</OEMDRO2_141>
<OEMLED2_141>0</OEMLED2_141>
<OEMDRO2_142>0.</OEMDRO2_142>
<OEMLED2_142>0</OEMLED2_142>
<OEMDRO2_143>0.</OEMDRO2_143>
<OEMLED2_143>0</OEMLED2_143>
<OEMDRO2_144>0.</OEMDRO2_144>
<OEMLED2_144>0</OEMLED2_144>
<OEMDRO2_145>0.</OEMDRO2_145>
<OEMLED2_145>0</OEMLED2_145>
<OEMDRO2_146>0.</OEMDRO2_146>
<OEMLED2_146>0</OEMLED2_146>
<OEMDRO2_147>0.</OEMDRO2_147>
<OEMLED2_147>0</OEMLED2_147>
<OEMDRO2_148>0.</OEMDRO2_148>
<OEMLED2_148>0</OEMLED2_148>
<OEMDRO2_149>0.</OEMDRO2_149>
<OEMLED2_149>0</OEMLED2_149>
<OEMDRO2_150>0.</OEMDRO2_150>
<OEMLED2_150>0</OEMLED2_150>
<OEMDRO2_151>0.</OEMDRO2_151>
<OEMLED2_151>0</OEMLED2_151>
<OEMDRO2_152>0.</OEMDRO2_152>
<OEMLED2_152>0</OEMLED2_152>
<OEMDRO2_153>0.</OEMDRO2_153>
<OEMLED2_153>0</OEMLED2_153>
<OEMDRO2_154>0.</OEMDRO2_154>
<OEMLED2_154>0</OEMLED2_154>
<OEMDRO2_155>0.</OEMDRO2_155>
<OEMLED2_155>0</OEMLED2_155>
<OEMDRO2_156>0.</OEMDRO2_156>
<OEMLED2_156>0</OEMLED2_156>
<OEMDRO2_157>0.</OEMDRO2_157>
<OEMLED2_157>0</OEMLED2_157>
<OEMDRO2_158>0.</OEMDRO2_158>
<OEMLED2_158>0</OEMLED2_158>
<OEMDRO2_159>0.</OEMDRO2_159>
<OEMLED2_159>0</OEMLED2_159>
<OEMDRO2_160>0.</OEMDRO2_160>
<OEMLED2_160>0</OEMLED2_160>
<OEMDRO2_161>0.</OEMDRO2_161>
<OEMLED2_161>0</OEMLED2_161>
<OEMDRO2_162>0.</OEMDRO2_162>
<OEMLED2_162>0</OEMLED2_162>
<OEMDRO2_163>0.</OEMDRO2_163>
<OEMLED2_163>0</OEMLED2_163>
<OEMDRO2_164>0.</OEMDRO2_164>
<OEMLED2_164>0</OEMLED2_164>
<OEMDRO2_165>0.</OEMDRO2_165>
<OEMLED2_165>0</OEMLED2_165>
<OEMDRO2_166>0.</OEMDRO2_166>
<OEMLED2_166>0</OEMLED2_166>
<OEMDRO2_167>0.</OEMDRO2_167>
<OEMLED2_167>0</OEMLED2_167>
<OEMDRO2_168>0.</OEMDRO2_168>
<OEMLED2_168>0</OEMLED2_168>
<OEMDRO2_169>0.</OEMDRO2_169>
<OEMLED2_169>0</OEMLED2_169>
<OEMDRO2_170>0.</OEMDRO2_170>
<OEMLED2_170>0</OEMLED2_170>
<OEMDRO2_171>0.</OEMDRO2_171>
<OEMLED2_171>0</OEMLED2_171>
<OEMDRO2_172>0.</OEMDRO2_172>
<OEMLED2_172>0</OEMLED2_172>
<OEMDRO2_173>0.</OEMDRO2_173>
<OEMLED2_173>0</OEMLED2_173>
<OEMDRO2_174>0.</OEMDRO2_174>
<OEMLED2_174>0</OEMLED2_174>
<OEMDRO2_17<br/><br/>(Message over 64 KB, truncated)
Group: DynoMotion Message: 5459 From: Tom Kerekes Date: 7/23/2012
Subject: Re: spindle speed is not changing at g96 mode mach3 turn
Hi Frank,
I tried your XML file with some unrelated changes to run on my system and it seems to work for me.  (in the future please attache the XML file rather than pasting it into the email).
I'm running Mach3 Lockdown version R3.043.022.
I don't think you should have PID setting and Averaging on for your Spindle control but even with those on it seems to work for me.  See Attached Screen shots.
You forgot to include your spindle.c program.  I used my own.  I recall you had some IO conditions to change the speed.  Run KMotion.exe and wath the Console Screen to check if you are getting messages.
I'm running in English mode, using the MDI I'm moving to X1, then entering G96S100M3 and then I observe continuous Spindle Messages.  If I move X by Jogging or with X1.1 the RPM changes.
Group: DynoMotion Message: 5636 From: frank_19_88 Date: 9/1/2012
Hi TK,
If I type g96 f200 s200 m3 in mach3 the console shows me one time:
Mach3 Notify Message=5, Direction= 0, Spindle Set to 0.014168
Spindle Speed Set to 0.014168
But it don't refresh when I move x. only when I press reset under spindle true it send the masage again to kflop.
My xml and spindle.c:
http://www.4stepsahead.nl/maho/Weiler_120.xml
http://www.4stepsahead.nl/maho/SpindleMach3DAC.c
Config | Ports and Pins | Spindle Setup | Relay Control | Disable Spindle Relays = 0
i did try to change multiple spindle settings within mach3 but without success.
I hope you have any idea why mach3 dont update the spindle speed,
With kind regards,
Frank
> Hi Frank,
> Actually CSS seems to be working for me.
> Make sure Config | Ports and Pins | Spindle Setup | Relay Control | Disable Spindle Relays
> is NOT checked.
> Otherwise Mach3 will not continuously send Plugin Messages while in G96 mode.
> Looks like it sends Spindle Messages at about 5X per second whether X is moving or not.
> It also took me a while to realize that S is in feet per minute.
> I still don't understand exactly what the +CSS value indicates.  Reciprocal of CSS or something.
> From: frank_19_88 <frank_19_88@...>
> Sent: Friday, July 20, 2012 12:23 AM
> Subject: [DynoMotion] spindle speed is not changing at g96 mode mach3 turn
> Hi TK,
> I am using mach3 turn.
> The machine is working very good.
> But when I use g96 the spindle speed would not update/change.
> The css is changing when the x axis is moving.
> When I press +,-,+,-,+,-,+,- at the spindle speed the spindle speed change: 3000rpm at x0 and 100 rpm at x100.
> This is a picture of the screen:
> http://www.4stepsahead.nl/frank/mach3.jpg
> Do you know why the spindle is not updating?
> With kind regards,
> Frank
Group: DynoMotion Message: 5637 From: Tom Kerekes Date: 9/3/2012
Hi Frank,
In the XML file you sent
is checked.  I get no updates when this is checked.  If I uncheck it then I get constant updates.
Please try it with it unchecked.  Uncheck it,  Save the Mach3 Settings, Exit and restart Mach3, Verify it is Un-checked.  Then retry it.
Group: DynoMotion Message: 5645 From: frank_19_88 Date: 9/5/2012
Hi TK,
I had to press ' Spindle CW, reset THC height 110' button. It lights up a led. Now it works perfectly.
With kind regards,
Frank
> Hi Frank,
> Sent: Saturday, September 1, 2012 5:06 AM
> Subject: [DynoMotion] Re: spindle speed is not changing at g96 mode mach3 turn
> Hi TK,
> With kind regards,
> Frank
> > Hi Frank,
> > is NOT checked.
> > From: frank_19_88 <frank_19_88@>
> > Hi TK,
> > With kind regards,
> > Frank
